Wall function implementation K Omega SSt
Old   August 17, 2009, 10:49
Default Wall function implementation K Omega SSt
Christopher Barry
cbarry is on a distinguished road
Hi everyone,
I've been having a closer look at the wall function for the kOmegaSST model for incompressible flow in OpenFoam 1.5.
I am new to OpenFOAM though and don't quite understand how the wall function is implemented in OpenFOAM. In literature it is quite commonly written that in the buffer zone, between the viscous sub-layer and the log layer, omega is calculated from a blending function of the form
omega = ('omega viscous'^2 + 'omega log layer'^2)^(1/2)
However, I can't find any such blending function in the OpenFOAM code. Am I just looking in the wrong place? Or does OpenFOAM simply not have spearate functions for the buffer zone?
If OpenFOAM does not use such blending functions, has anyone tried implementing them?
Best regards,
Chris
cbarry is offline   Reply With Quote
Old   August 17, 2009, 10:59
Anonymous
madad2005 is on a distinguished road
Someone can correct me if I'm wrong, but the SST model in foam has no blended wall functions (infact, I'm not sure if any of the turb models do), although I don't think it is that difficult to add in a simple one like that which you just mentioned. I plan to do it at some point in September, so let me know if you get anywhere with it.
madad2005 is offline   Reply With Quote
Old   August 18, 2009, 03:21
Christopher Barry
Thank you Adriano. I'll try implementing some new blended wall functions then. I was hoping I could just modify existing ones.
Old   August 18, 2009, 11:09
Christopher Barry
I've had another look at the wall function files in OpenFOAM.
It looks like OpenFOAM uses the wall function
omega_[faceCelli] +=
sqrt (k_[faceCelli])
/ (Cmu25*kappa_.value()*y_[faceCelli])
regardless of what sublayer of the turbulent boundary layer it is in.
There must however be an upper bound y+ value upto which the wall function applies. Does anyone know where in the code this upper bound is?
blending, buffer zone, komegasst, omega, wall function
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
