directMapped BC in parallel
Old   August 13, 2009, 07:35
Default directMapped BC in parallel
Johann Turnow
turnow is on a distinguished road
Hi all togehter,
I was setting up an LES with the directMapped BC in parallel with the new svn checkout of version OF-1.5-dev. On a single processor the BC works well but while starting it in parallel mode (more than 2 cores) it keeps stopping before solving the momentum equation. Even the Tutorial pitzDailyDirectMapped does not work on 4 cores.
Also the debug modus shows no problems.
so can anyone give me a hint, where to start solving this problem?
thanks,
Johann
turnow is offline   Reply With Quote
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 12:49
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
