sliding meshes
Old   August 12, 2009, 09:23
Default sliding meshes
Vojtech Betak
betakv is on a distinguished road
Hi, I've problem with a geometry which is simply described in attached file. The rotor1 has right-hand rotation and the rotor2 has left-hand rotation.
I've used the MRFSimpleFoam for solution. The results are good and I want try a simulation with sliding meshes. Is there any possibility make this simulation in OpenFOAM? I will try a solver, which is described in mixerGgi, but I don't know how to describe this geometry into dynamicMeshDict.
Can you give me an advice?
Thank's a lot.
Vojta
betakv is offline   Reply With Quote
Old   August 12, 2009, 13:34
Henrik Rusche
henrik is on a distinguished road
Dear Vojta,
The geometry is not described in dynamicMeshDict, but is imported with the mesh which is created by blockMesh in this particular tutorial. The mechanics (point motion, attach, detach) is handled in dynamic mesh motion classes:
$FOAM_SRC/topoChangerFvMesh/mixerFvMesh/mixerFvMesh.C
OR
$FOAM_SRC/dynamicFvMesh/mixerGgiFvMesh/mixerGgiFvMesh.C
which read their controls from dynamicMeshDict.
To get your case off the ground, you need to do three things: a) find a way to create the initial mesh; b) Modify the dynamic mesh motion classes to select and rotate two regions; c) Modify the dynamic mesh motion classes to create and operate two interfaces.
A word of warning, the sliding interfaces don't like corners, but GGI will be okay.
Henrik
henrik is offline   Reply With Quote
sliding meshes Tim Daly FLUENT 3 November 20, 2008 09:20
Boundaries swapt with sliding meshes guido_adriaensen OpenFOAM Running, Solving & CFD 0 January 31, 2006 03:55
sliding meshes with periodic BC's Dan Brozozowski FLUENT 3 June 27, 2003 08:10
Grid angle in sliding meshes mystic_cfd FLUENT 0 October 1, 2002 07:07
Empty surface in sliding meshes. Pierre Ricco FLUENT 2 March 14, 2001 17:01
