August 8, 2009, 11:33 |
Running Problem using Openfoam solver
Rep Power: 17 |
Hi all,
I am a new user to OpenFOAM, I have caarried out solver setting in STAR-CD ( PRO-STAR). 1.Can i know how to convert this file to run in OenFOAM 2.Please give link, which provides about setting up run commands. 3.How to convert the result file to STAR-CD for Post-Processing. Thanks & regards cfd_staruser |
August 8, 2009, 12:05 |
Disabled
Rep Power: 17 |
you can find this in the decoumentaion of openfoam on the www.openfoam.com
at the page U-87 but it is how to convert from star-cd to openfoam mybe you find there more |
August 8, 2009, 12:06 |
Disabled
Rep Power: 17 |
and page U88 is how to postprozess convert from openfoam to star-cd
August 12, 2009, 23:21 |
Thank you
Rep Power: 17 |
Thanks for the response provided.
I went through the document, i got the procedure for file conversion method. However the tutorial consists of time interval problem. can u help me in setting the problem setup for a steady state case. regards cfd_staruser cfdstaruser@googlemail.com |
August 13, 2009, 04:06 |
Disabled
Rep Power: 17 |
do you mean the directory of times in the case folder???
i dont understand you question |
August 14, 2009, 03:28 |
Markus Rehm
Rep Power: 17 |
check out the simpleFoam solver. Markus |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 19:31 |
CFX 11 x64 solver? problem | Attesz | CFX | 6 | June 7, 2009 09:37 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 11:21 |
Manage openfoam solver project in KDevelop probably the last linker error any suggestion is welcome | lakeat | OpenFOAM Installation | 0 | July 7, 2007 11:01 |
CFX 5.6 memory problem with solver | sreevisakh | CFX | 3 | February 2, 2004 05:57 |
