August 5, 2009, 12:39 |
Editing RSTM Turbulence Model
Sven Winkler
Rep Power: 17 |
Hi everyone,
I want to edit the LaunderGibsonRSTM turbulence model which comes with OpenFOAM. More exactly I want to change the equation for the Reynolds Stresses in this model, so that it becomes a new modelling approach. I copied the Folder with the model and renamed it with the name of the new model and I also renamed the files within this copied folder. Then I began to edit the .C and .H file and it seemed to work. But unfortunately I get an error while compiling the edited file. The eror tells me that LHS and RHS (Left- and right Handside) of the equation I edited no longer have the same Dimensions. I think this is because I deleted some Coefficients in this equation and added some new ones. Sadly I cant find where the dimensions of these constants are implemented. Did anyone encounter this problem too or does anyone know how to solve it? Thanls a lot |
August 5, 2009, 13:09 |
Sven Winkler
Rep Power: 17 |
I thought the posted error message might probably help:
LHS and RHS of - have different dimensions dimensions : [0 0 0 0 0 0 0] - [0 0 -1 0 0 0 0] #0 Foam::error::printStack(Foam::Ostream&) in "/home/sven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/sven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::operator-(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/home/sven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<Foam::SymmTensor<double>, Foam::SphericalTensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::operator-<Foam::SymmTensor<double>, Foam::SphericalTensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<Foam::SphericalTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/sven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libincompressibleRASModels.so" #4 Foam::incompressible::RASModels::LaunderGibsonModified::correct() in "/home/sven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libincompressibleRASModels.so" #5 main in "/home/sven/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/turbFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 _start in "/home/sven/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/turbFoam" From function operator-(const dimensionSet& ds1, const dimensionSet& ds2) in file dimensionSet/dimensionSet.C at line 423. FOAM aborting |
September 18, 2009, 06:29 |
Sven,
from your error out put you have some mismatch of dimensions in substraction of two values in Foam::incompressible::RASModels::LaunderGibsonModi fied::correct() method. Analyze it if all parts have the same dimensions. As a hint: it is better first to analyze equations on paper if they are correctly stated before transitioning them to source code. Good luck!
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model | us | FLUENT | 5 | April 5, 2011 03:29 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 11:26 |
validating turbulence model on flow around a car | Pedro | CFX | 1 | February 20, 2008 17:32 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 17:15 |
