September 24, 2009, 03:04 |
#21 |
Mads Reck
Rep Power: 18 |
Oh, the setup you mention is more than possible. It's used on a daily basis in both the wind turbine industry, in commercial car development and very much so in the racing car industry. And many more.
Point is, these companies probably have substantially faster computer hardware than you have and they do this all the time. This makes them able to use fine, optimized, meshes and also to be aware (through experience on each particular setup) of the impact of simplifications applied to the CFD-models. CFD is playing a key role in a broad range of industries, only mentioning a few of them above. So the answer to your question "is CFD useful for testing cars or planes?" is a loud YES, and it has been for quite some years now. You have a point, though, that CFD is often used as a qualitative tool more than a quantitative one. It's easier to get contour plots and streamlines from CFD than correctly predicting lift and drag, within 1% of experimental results, on a stalled airfoil. BR Mads
Online free airfoil-mesher for OpenFOAM here |
airfoil2d, blockmeshdict, simplefoam |
running without rsh between nodes | hattonps | OpenFOAM | 10 | March 22, 2010 16:02 |
What do you CFD guys do during a long simulation running? | bearcat | Main CFD Forum | 5 | July 23, 2009 09:08 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
Tutorial is not running on star-CD version 3.2 | Arnab | Siemens | 0 | August 30, 2004 16:43 |
star is not running the simulation in windows | Arnab | Siemens | 1 | August 2, 2004 03:40 |
