Mesh conversion
Old   July 30, 2009, 05:29
Exclamation Mesh conversion
varun
vw.cfd is on a distinguished road
I have a query in mesh conversion. I export my mesh from fluent to foam using fluentMeshToFoam. My question is since i make the mesh in "mm", do i have to scale mư mesh or specify anywhere that my mesh is in "mm". As the standard unit of measure in Openfoam is "m".
Please help!!
ThnX a ton in advance..
vw.cfd is offline   Reply With Quote
Old   July 30, 2009, 06:48
Ville Tossavainen
villet is on a distinguished road
I think first you should check the mesh using "checkMesh" utility. If the domain box looks like being in millimeters, you can scale the mesh using command "transformPoints -scale "(0.001 0.001 0.001)"".
Ville
villet is offline   Reply With Quote
Old   July 30, 2009, 07:15
Henrik Rusche
henrik is on a distinguished road
Alternatively,
you can use the -scale:
Usage: fluentMeshToFoam <Fluent mesh file> [-writeSets] [-case dir] [-writeZones] [-scale scale factor] [-help] [-doc] [-srcDoc]
Henrik
henrik is offline   Reply With Quote
Old   July 30, 2009, 08:12
varun
Thank you!!
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
Help: mesh conversion from Gambit to ICEM sarah_ron2002 FLUENT 2 April 5, 2008 02:53
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
