define cutting plane - parallel running
Old   July 24, 2009, 05:50
Question define cutting plane - parallel running
Julien Schaguene
Schag is on a distinguished road
I'm looking for a solution to define a cutting plane for parallel running.
My domain is a U pipe, with an inlet lenght different from the outlet one.
Looks like that:
inlet...... xxxxxx
.................... x
outlet xxxxxxxxx
The problem is that methods simple/metis/herarchical do not cut it at the middle of the U turn, so the interface is not optimal. I could eventually use a manual method, but don't have an example of implementation. Is there another solution?
Regards
Julien
Schag is offline   Reply With Quote
Old   July 24, 2009, 06:21
Henrik Rusche
henrik is on a distinguished road
Julien,
how many processors?
It's important to have an equal amount of cells on each processor. The size of the processorProcessor patch is secondary.
Henrik
henrik is offline   Reply With Quote
Old   July 24, 2009, 08:44
Julien Schaguene
Only 2 processors for the moment, about 160k cells each...and 1200 faces for interface.
I have no temporal gain compared to monocore simulation...
Old   July 24, 2009, 09:03
Henrik Rusche
Dear Julien,
did you start your simulation in parallel?
mpirun -np 2 julienFoam -parallel
Henrik
Old   July 24, 2009, 09:42
Julien Schaguene
yes, I did that correctly I think, I used that command line, and my 2 processors are busy.
I have a gain in executionTime, but not in clockTime (and the computer isn't doing anything else at the same time).
I though, maybe my computer is not adapted to that kind of parallel using. (AMD Athlon(tm) Dual Core Processor, Debian 64bit)
Old   July 24, 2009, 11:26
Henrik Rusche
Julien,
your hardware is fine.
I am confused about this. Please post the log of last few iterations.
Please check in top that the two processes together consume about the same memory than the single processor process.
Which parallel comms library are you using?
echo $WM_MPLIB.
Try a different one. LAM rather than OPENMPI or vice versa. You probably need to compile Pstream.
Incidentely, is this a binary installation? If yes, it might be worth a try recompiling everything.
Henrik
cutting plane, parallel
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 19:31
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Running in parallel s.sivakumar OpenFOAM Running, Solving & CFD 3 July 4, 2009 01:37
Getting error while running on parallel Mode velan OpenFOAM Running, Solving & CFD 8 May 10, 2009 04:26
Problems on running cfx in parallel Nan CFX 1 March 29, 2006 05:10
