July 22, 2009, 20:02 |
azimuthal component in U boundary condition
Jerry Lee
Rep Power: 17 |
I have a 3-D cylindrical domain (mesh is cartesian) and would like to add a constant azimuthal (theta direction) component to the inlet boundary for U. Now, there doesn't seem to have a primitive patch field type for this. Does anyone know how this can be done without having to calculate the list of U for each cell surface on the patch?
Many thanks in advance. |
July 22, 2009, 23:48 |
David P. Schmidt
Rep Power: 17 |
Hi Jerry,
Are all three vector components of the boundary invariant in time? If so, I would recommend funkySetFields. It allows you to set fields with expressions. Normally, it is used for setting initial conditions, but if it is writing volVectorFields, I suspect that it will write the values for the boundaries too. See: http://openfoamwiki.net/index.php/Co...funkySetFields -David |
July 22, 2009, 23:56 |
David P. Schmidt
Rep Power: 17 |
Jerry,
Ignore funkySetFields. I forgot about groovyBC, another of Bernhard's whimsical masterpieces. That would cut right to the chase. It lives in the OF1.5 dev breeder too. see http://openfoamwiki.net/index.php/Contrib_groovyBC for documentation. If it would help, my student Kshitij wrote a brief PDF that explains the nomenclature used in OF's mixed BC's. Email me and I can send it to you. -David |
September 2, 2009, 09:44 |
Explanation of mixed BC's
#4 | |
David P. Schmidt
Rep Power: 17 |
All,
It makes more sense if I publish this here. Wish me luck with the attachment. It is a gzipped PDF (to get it small enough to be posted as an attachment). -DPS Quote:
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
outlet boundary condition | Nina Schiepel | CFX | 2 | July 12, 2008 16:27 |
spanwiperiodic boundary condition for LES | Sungho Yoon | CFX | 5 | July 8, 2008 07:21 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 07:40 |
1 and 2 Order Boundary condition at the same place | CFD_Flo | Main CFD Forum | 4 | July 11, 2005 12:57 |
