July 22, 2009, 07:36 |
Loading geometry to OF 1.5
Paavo Mäkelä
Rep Power: 17 |
Hi
I am very new to OpenFOAM and I'm not sure if I'm doing this the right way... I want to load some geometry into OF which I modeled in Catia and added a bounding box to the .stl file in another cad package. Do you usually model a separate bounding box (ie. walls) or do you add this somehow later by editing something in /polyMesh/? Anyway, I managed to mesh the model in Netgen by merging the meshed model with the meshed bounding box. I'm able to see these in Paraview, but how do I setup which of the patches of the bounding box is the inlet & outlet? Or again, would you define these separately in polyMesh? netgenNeutralToFoam doens't load this geometry to OF because of multiple domains (netgenNeutralToFoam export results would allow editing the separate patches as inlet/outlet..), and while the fluent3DMeshToFoam loads the geometry properly, I won't be able to define the inlet/outlet because the walls are one lump of 3d data in constant/polyMesh. Thanks for any advice! - pm |
Gambit geometry creation: loading data to gambit | C Ariyaratne | FLUENT | 10 | March 17, 2011 17:39 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
Fluent Geometry Limitations | jpinho | FLUENT | 0 | June 23, 2009 08:37 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
