July 19, 2009, 10:04 |
movingCone without stretching the mesh
Disabled
Rep Power: 17 |
hello
is it posible to move the cone without strtching the mesh with the posiblity of Cell layer additional-removal interface how could i reals this and is it posible to change the speed of the motion of the cone (with timedependent motion) timedependent form the flowtime?? Form: init the first 2 pic and the last to pic are the end |
July 19, 2009, 10:16 |
Disabled
Rep Power: 17 |
soory! here are the next tow pic
July 20, 2009, 05:21 |
Henrik Rusche
Rep Power: 18 |
Dear Tajoooko,
have a look at the following tutorial in 1.5-ext $FOAM_TUT/tutorials/icoDyMFoam/movingConeTopo Have a look here for how to obtain 1.5-ext http://openfoamwiki.net/index.php/Ho...M_the_easy_way and other post on the forum. Henrik Last edited by henrik; July 20, 2009 at 06:26. |
July 20, 2009, 05:40 |
Disabled
Rep Power: 17 |
hello the
movingConeTopo is not in the tutorials i instaled the openfoam-1.5 but there is this tutoral not icluded |
July 20, 2009, 06:37 |
Henrik Rusche
Rep Power: 18 |
Dear Tajoooko,
you need 1.5-extend, not the 1.5 (plain, vanilla) or 1.5.x (patched vanilla, git) version, because what you want to do requires topological mesh changes. http://www.cfd-online.com/Forums/ope...x-1-5-dev.html Henrik |
July 20, 2009, 08:30 |
Disabled
Rep Power: 17 |
ok thank you very much danke dir
now i am downloding the extended about 800MB but i dont found an install document, to install it like an extende (erweiterung) to the openfoam |
July 20, 2009, 08:46 |
Henrik Rusche
Rep Power: 18 |
Dear Tajoooko,
you are probably downloading the OpenFOAM on SLAX tar-ball which is a full operating system to put on a USB stick. It's probably not what you want, but it's very nice for beginners. Instructions are here: http://www.cfd-online.com/Forums/ope...lax-based.html If you are aiming for the "normal" OF-1.5-ext installation. Follow the link in my first post. There is no binary pack, so you must compile from source. Henrik |
July 20, 2009, 11:35 |
Disabled
Rep Power: 17 |
i downloaded this and burn a cd
OpenFOAM_SLAX_noDebug.iso and now how should i install openfoam from this iso cd??? |
July 20, 2009, 11:44 |
#9 |
Henrik Rusche
Rep Power: 18 |
No, put it into the drive and reboot, but make sure the boot order picks up the CD first.
Henrik |
July 20, 2009, 12:01 |
#10 |
Disabled
Rep Power: 17 |
ok i do that, and that is not an alternativ
i need the real openfoam-1.5-dev i will try to do that but it seems to be more difficult that the normal openfoam i get the normal openfoam quickly installed but this version is making some problemes i would wirte here again |
July 21, 2009, 10:41 |
#11 |
Disabled
Rep Power: 17 |
hello
i download openfaom-1.5-dev and the other tgtz files form the openfoam webside then i rename openfoam1.5-de to openfoam 1.5 and unpake the tgtz files then i remane openfoam1.5 to openfoam 1.5-dev then i unpake the tgtz of thirdparty and do update my ~/.bashrc then .$HOME/.bashrc after that i do the installation test from openfaoam and every thing was ok the icofoam solver and the blockMesh all was there (i just typ it in the bash) after that i cd in the openfoam-1.5-dev and typ ./Allwmake this takes alout of time about 2 or 3 hours and then every think was fisched but the problem now the path dont work any more i canot typ blockMesh or something other there is nothing more i have do cd in the directory ob bin and take them from there what is worng?? |
July 21, 2009, 10:55 |
#12 |
Henrik Rusche
Rep Power: 18 |
Dear Tajoooko,
Start a fresh shell and run foamInstallationTest. If it cannot be found, check your environment settings until you it's picked up. Henrik |
July 21, 2009, 11:04 |
#13 |
Disabled
Rep Power: 17 |
ammar@ammar-laptop:~$ foamInstallationTest
Executing /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: ammar-laptop OS: Linux version 2.6.27-14-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/ammar/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/ammar/OpenFOAM/ammar-1.5-dev yes no $WM_THIRD_PARTY_DIR /home/ammar/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/ammar/OpenFOAM/OpenFOAM-1.5-dev yes yes yes $FOAM_APPBIN ...5-dev/applications/bin/linuxGccDPOpt yes yes yes $FOAM_USER_APPBIN ...5-dev/applications/bin/linuxGccDPOpt yes yes no $WM_DIR ...mmar/OpenFOAM/OpenFOAM-1.5-dev/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...M/OpenFOAM-1.5-dev/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...FOAM/ammar-1.5-dev/lib/linuxGccDPOpt yes yes no $MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../src/configure Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.20 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_ammar-laptop Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
July 21, 2009, 11:24 |
#14 |
Henrik Rusche
Rep Power: 18 |
Dear Ammar,
The problem is here: icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam I think you might have two OF installations in you PATH ... Henrik |
July 21, 2009, 12:14 |
#15 |
Disabled
Rep Power: 17 |
yeh that could be wirte bcz i tryed it with the build surce form debian but it was not good and then i thougt i geet it uninstalled
with sudo apt-get --purge remove openfoam-dev-1.5 and then i first do install that again but it could also be a gcc problem bcz i installed it also tow times, is there a posibility to get that problem out ? |
July 21, 2009, 14:03 |
#16 |
Henrik Rusche
Rep Power: 18 |
Dear Ammar,
sorry, but it seems to me that you are not taking advice and trying out alternative routes. I don't care if want to you waste your time, but I do object to wasting mine. Please remove all those clever OF binary packages that make you life difficult. However, keep the vanilla OF 1.5 that you picked up from OpenCFD as a fall-back and in case you have trouble compiling paraFoam. Go to the directory with the OpenFOAM-1.5 and ThirdParty directories (cd $FOAM_INST_DIR) and pull the latest OF-ext: Code:
svn co https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev @GCC: Anything > 4.2.0 will be fine as long it's compatible with your system. Henrik |
July 22, 2009, 03:42 |
#17 |
Disabled
Rep Power: 17 |
I do it again on another way and now it works very fine so dont be warry
and thank you very very much (danke dir sehr) i would wirte a how to install openfoam on ubuntu 8.10 and i would wirte how to install the paraview form the apt/synaptic to geht the newist one without a problem and by one klick |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 05:27 |
virtual geometry | richard | FLUENT | 4 | January 7, 2009 06:16 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 14:47 |
