Implementation of div, laplacian, etc and variables |
July 16, 2009, 12:07 |
Sven Winkler
Rep Power: 17 |
Hi everyone,
I want to edit the LaunderGibson RSTM provided with the normal OpenFOAM distribution. Before I can do this, I first need to understand the originally implemented model. For doing this I need to know where exactly, that is in which file of the OpenFOAM package the functions div, laplacian, etc are defined. Does anyone know in which file these are defined? Furthermore, how can I figure out where variables like U or R are defined in OpenFOAM (that is again, in which file)? Thanks for your help! |
July 18, 2009, 06:52 |
#2 | |||
Henrik Rusche
Rep Power: 18 |
Dear Sven,
$FOAM_SRC/finiteVolume/lnInclude/fvmDiv.H $FOAM_SRC/finiteVolume/lnInclude/fvmLaplacian.H and so forth The upwind-scheme, for example, is defined in line 132 of $FOAM_SRC/finiteVolume/lnInclude/upwind.H Quote:
$FOAM_SOLVERS/incompressible/turbFoam/createFields.H (lines 15-27) Hope this helps, Henrik |
July 19, 2009, 15:31 |
Sven Winkler
Rep Power: 17 |
First of all thanks for the reply. I scanned through the files you mentioned and I could find all of the definitions and all the variables I was looking for. But I want to see of what kind the variables are (array with size, scalar, etc.). I think this is defined by words like "volVectorField", so I guess there must be another file in which this volVectorField is defined. Is this correct? and if so, where can I find this file? Thanks a lot!
July 19, 2009, 18:18 |
Henrik Rusche
Rep Power: 18 |
Dear Sven,
R is instantiated in LaunderGibsonRSTM.C: Code:
R_ ( IOobject ( "R", runTime_.timeName(), mesh_, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh_ ), Henrik |
