question on reactionFoam
Old   July 15, 2009, 17:50
Default question on reactionFoam
Jerry Lee
leejc is on a distinguished road
I have just started with OpenFoam and am trying to test it out with a mixing problem (two streams: air and a gas into a chamber with one exit plane in the turbulent regime RAN is fine). Is there an existing solver that can handle this?
Many thanks in advance.
leejc is offline   Reply With Quote
Old   July 16, 2009, 03:38
Markus Rehm
markusrehm is on a distinguished road
have a look here
http://www.tfd.chalmers.se/~hani/kur...actingFoam.pdf
and here
http://openfoamwiki.net/index.php/Tu..._firstTutorial
Markus
markusrehm is offline   Reply With Quote
Old   July 16, 2009, 15:57
Default problem.. missing file
Jerry Lee
Thank you very much for the quick response.
I tried to run the reactingFoam turorial with OpenFoam 1.5 and it conplains that the a file RASProperties is missing in the constant director. Does anyon know what this file should be?
Old   July 16, 2009, 16:02
Jerry Lee
Please ignore my previous message. I found RASProperties.. file containing spec. for the turbulence model..
Thank you Markus
Unanswered question niklas OpenFOAM 2 July 31, 2013 17:03
question about implementing boundary conditions saygin Main CFD Forum 0 July 6, 2006 08:08
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 06:55
question K.L.Huang Siemens 1 March 29, 2000 05:57
