July 2, 2009, 13:14 |
IcoDyMFoam crashing after a particular time.
Shaurya Verma
Rep Power: 17 |
I'm simulating the fuel injection system of a diesel engine using openfoam. Now, for the entire inlet open - inlet closed process, the mesh varied too much and I had to change the mesh twice.
In the 0.5 milliseconds that the process would take I had to have the mesh recreated at 0.15 ms and 0.3 ms. In the first transition, the no. of cells remained unchanged, and in the second transition the no. of cells had to be changed from 5999 to 5615. I'm using quadratic inverse distance 1 diffusion model and velocityComponentLaplacian solver. Whatever I do, I can simply not get past 0.31 milliseconds. The mesh doesn't fail, so I can use moveDynamidMesh but when I try to simulate the values of velocity and pressure using icoDyMFoam, it fails around that region. I've tried 3 other diffusion models but to no avail. The error that I got most recently is as follows:- --> FOAM Warning : From function polyBoundaryMesh:atchSet(const wordList& patchNames) in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 429 Cannot find any patch names matching movingWall DICPCG: Solving for cellMotionUx, Initial residual = 5.39908e-05, Final residual = 9.86322e-09, No Iterations 24 DILUPBiCG: Solving for Ux, Initial residual = 0.999757, Final residual = 2.97334e-06, No Iterations 11 DILUPBiCG: Solving for Uy, Initial residual = 0.999757, Final residual = 1.53516e-07, No Iterations 14 DILUPBiCG: Solving for Uz, Initial residual = 0.000829198, Final residual = 5.60623e-06, No Iterations 4 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7f09400] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #5 main in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoDyMFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/shaurya/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoDyMFoam" Floating point exception don't worry about the movingwall FOAM Warning, that is certainly not the cause, in fact that has intentionally been done. What should I do. I've already spent two futile days on this juncture in this problem. Thanks in advance. |
July 2, 2009, 13:15 |
Shaurya Verma
Rep Power: 17 |
also, my apologies for the smileys in the message, evidently they are : p (without the space) that have been automatically corrected to .
i will just reiterate for clarity, during the first transition to a new mesh everything goes okay (from 0.15ms to 0.3ms) however, after the second transition, in which i use mapfields again, the code crashes very soon (after ~0.01ms). Interestingly, I tried to start with the new mesh from 0.25 ms instead of 0.3 ms, and icoDyMFoam crashed around 0.26 ms. Last edited by Shaurya; July 2, 2009 at 13:48. |
July 2, 2009, 16:47 |
Sachin Kanetkar
Rep Power: 17 |
hi
have very little idea ...why it is failing ....maybe this can help http://openfoamwiki.net/index.php/HowTo_debugging |
error, icodymfoam, moving mesh, openfoam |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
Time step size and max iterations per time step | pUl| | FLUENT | 31 | October 23, 2020 23:50 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
FSI time | YY | CFX | 0 | April 25, 2008 13:38 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
