automatic call a function in a program
Old   June 22, 2009, 04:38
Default automatic call a function in a program
Gerard Mouokue
gerado is on a distinguished road
I have a program and want to call automatically another function in my program . for example
int main (){
myprogram
gambitToFoam "gambitmesh"
return 0;
gerado is offline   Reply With Quote
Old   June 22, 2009, 06:54
4xF
Frank Albina
4xF is on a distinguished road
Send a message via Skype™ to 4xF
Hi Gerard!
in your case, wouldn't it be more adequate to change your program into a shell or python script? If you just manipulate data an/or files, this is the most portable and efficient way of doing it.
Else, you still have the call to system() from <stdlib.h>, but you will need to make sure you find the executable, i.e. you might need to input the full path. This has the drawback that you will need to recompile your code every time you change the executable (here gambitToFoam) is in another location.
The shell/python/perl/etc... scripts on the other can get the path to the executable from the environment variables. It's up to you to decide which strategy suits you best.
4xF is offline   Reply With Quote
Old   June 25, 2009, 03:36
Gerard Mouokue
Hi Frank ,
I have a c++ code and don't want to transform the code in a script . my problem is that I want at some place of my program to call the function GambitToFoam without having to tipp it myself .
Old   June 25, 2009, 08:13
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Actually according to the man page, "/bin/sh -c command" is called. Thus there's no need to resolve the path beforehand.
There is also a Foam::system(const string&) available from OSspecific, so you can also call it with C++ strings.
olesen is offline   Reply With Quote
Old   June 25, 2009, 09:05
Gerard Mouokue
hi Mark,
thanks for your advice. the problem it is not possible with Foam::system(const string&) to solve my problem.
I want to call this function
fluentMeshToFoam file.msh
where file.msh is the fluent mesh and fluentMeshToFoam convert it to OpenFoam
Old   June 25, 2009, 09:10
Mark Olesen
Originally Posted by gerado View Post
hi Mark,
What problem does the system report when you call the function?
#include "OSspecific.H"
   system("fluentMeshToFoam file.msh")
/mark
Old   June 25, 2009, 10:23
Gerard Mouokue
/mark
when I run my code I have
Fehler: »fluentMeshToFoam« wurde in diesem Gültigkeitsbereich nicht definiert
that means fluentMeshToFoam ist not defined in this scope
Old   June 25, 2009, 10:41
4xF
Frank Albina
This is not very surprising: Your environment variables are not loaded, so the OpenFOAM paths are not available and so is the executable fluentMeshToFoam... What I said earlier: Make sure that the path is set before calling the executable. If I were you, I'd try:
system("<myPathToTheOFInstallationDir>/etc/bashrc; fluentMeshToFoam file.mesh");
Old   June 25, 2009, 10:47
Mark Olesen
Check that fluentMeshToFoam can even be found *before* starting your program. In general you can send just about anything to system(). For example:
    system("echo PATH=$PATH | sed -e 's/:/\\n/g'");
    system("echo look for fluentMeshToFoam; which fluentMeshToFoam");
Old   June 29, 2009, 03:30
Gerard Mouokue
hi Mark ,Frank,
thanks for your help . it works
Gerard
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
