Write out turbulence model functions
Old   June 10, 2009, 23:35
Default Write out turbulence model functions
CFD user
bae127 is on a distinguished road
I am trying to modify turbulence models and would like to write out the value of some functions. For example, in kOmegaSST.C there is a private member function called F1. I would like to write out the value of this function each time I write out the other dependent variables.
I have tried the following syntax:
if(runTime_.outputTime())
F1.write()
While technically this works, the file name which is created is not "F1", but the function representation of F1 (e.g. tanh(pow4(min(min(max((((1|betaStar)*sqrt....)
Is there any way to force OpenFOAM to name this file something meaningful, like "F1"?
bae127 is offline   Reply With Quote
Old   June 10, 2009, 23:47
Default try IOobject
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
F1_
IOobject
"F1",
runTime_.timeName(),
mesh_,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh_
what you want to modify?
waynezw0618 is offline   Reply With Quote
Old   June 11, 2009, 00:23
Default Thanks
CFD user
Thanks for the help. I thought I had tried this before, and it did not work. I copied your syntax and everything works fine. I must have had a typo.
While the IOobject works, I am still wonding if there is a possibility of using the ".write()" function to accomplish this. The problem with the IOobject approach is that it requires a user to add an initial condition for "F1". This is not hard, but if an inexperienced user does not know that they need this initial condition, it can lead to lots of questions for me. Does anyone know the syntax to accomplish this with ".write()" ?
Old   June 11, 2009, 02:38
wayne.zhang
No it does work
i use this to output F1,and you could find out in the post before.
for initial condition i think it is not important for steady calculation.it is just a guess and after iteration it will get the correct values.
Old   June 11, 2009, 04:44
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
You could also change the
IOobject::MUST_READ
to
IOobject::NO_READ
and use a different constructor for the F1
Best regards,
Niels
ngj is offline   Reply With Quote
Old   June 11, 2009, 08:37
Default NO_WRITE does not work
CFD user
NGJ,
I know that I have tried this before... and I just did to reconfirm. If I make this change to my current code, it will compile fine. However, at run time I get an error like...
NO_READ specified for read-constructor of object F1 of class IOobject#0 Foam::error:rintStack(Foam::Ostream&) in "/home/edge/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/edge/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::regIOobject::readStream() in "/home/edge/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
You mentioned using a different constructor for F1. Could you elaborate on this a little? I appologize; I am a long time Fortran 90/95 user and am still working on learning C++.
Old   June 11, 2009, 08:52
ngj
Well, then welcome to the world of C++
What I mean by using a different constructor is that you can choose to set it to the field of another volScalarField, e.g.
volScalarField F1
IOobject
"F1",
runTime.timeName(),
mesh,
IOobject::NO_READ,
pd
as initialization, and then you can set the values on run-time! Note that the one you have used initializes based on the mesh, whereas my initializes based on another volScalarField. You will be able to find examples of this use in e.g. /interFoam/createFields.H.
You can find the documentation here:
http://foam.sourceforge.net/doc/Doxy...onedField.html
Hope it did help,
Best regards,
Niels
Old   June 11, 2009, 08:58
Default Thank you
CFD user
Niels,
Thank you for the explanation. It is very helpful.
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 14:54
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Turbulence Model GG Siemens 3 March 3, 2008 20:06
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 07:12
