Dimensions of skewCorrectionVectors
Old   June 2, 2009, 05:29
Default Dimensions of skewCorrectionVectors
Ivor Clifford
cliffoi is on a distinguished road
I am implementing a new surface interpolation scheme and have noticed that the skewCorrectionVectors class returns a dimensionless field. Shouldn't the dimensions of this field be dimLength, especially since this is dotted with the gradient of the field to obtain the correction?
Does anybody have any comments?
cliffoi is offline   Reply With Quote
Old   June 3, 2009, 06:47
Hrvoje Jasak
Hi Ivor,
Have a look at the non-orthogonal correction vectors and do the same
Hrv
Hrvoje Jasak
Old   June 12, 2009, 11:08
Ivor Clifford
Hi Hrv,
Thanks for your replay and sorry for my delayed response. I did notice that this is not an issue if you work with the field components. I was just curious why the dimensions were not strictly correct.
Ivor
Old   June 12, 2009, 13:18
Hrvoje Jasak
Can you fix it?
Hrv
Hrvoje Jasak
Old   June 15, 2009, 11:36
Ivor Clifford
Well, yes... just need to replace the keyword dimless with dimLength. I'm not so sure what the downstream result might be though. It seems like the only class which makes use of skewCorrectionVectors is skewCorrected so this is all that could potentially break (I hope). Here we go. If you would like me to upload it to the extend server, I don't yet have a login for this.
Regards
Ivor
Different dimensions for FATAL ERROR retech OpenFOAM Running, Solving & CFD 2 August 14, 2007 11:17
Confused by dimensions of Presure jack2000 OpenFOAM Running, Solving & CFD 3 June 5, 2007 11:24
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 15:34
Fluent: changing dimensions of a geometry genetaed Madhukar Rapaka FLUENT 3 October 12, 2005 12:40
SOURCE DIMENSIONS Andreas Abdon CFX 1 March 13, 2000 11:51
