May 26, 2009, 23:18 |
How to open two case in paraview?
Gy WANG
Hello,all.
I am learning the tutorials by User Guide of OpenFOAM-1.5, but now a problem appears as discribed in the thread title. I want to open the cases of cavity and cavityFine simultaneously. As metioned in the user guide, page 33, "For example, to load the cavityFIne case the file would be created by typing at the command prompt:....." Here, does the command prompt mean the terminal? But when I type the "cd..." and "touch" command, and then run "paraview", click "open" menu, the directory tree appears. But when I click the cavityFine.foam, the message appears "terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create aborted" It's very appreciated to you for detail explaination. I compiled OpenFOAM1.5 in debian lenny, with an error: Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../src/configure 4.3.2 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.20 /bin/tar icoFoam 1.5 ...AM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- I don't know it is ok or not. But the cavity case works well. |
May 27, 2009, 03:25 |
#2 | |
Mark Olesen
Rep Power: 40 |
Finally, I'd suggest that you use the 1.5.x from the git repository - it contains a number of important bug fixes. |
June 2, 2009, 05:20 |
Simple multiple region paraFoam wrapper
Ivor Clifford
Rep Power: 17 |
I've just dealt with the same issue myself. The wiki gives two suggestions to do this.
http://openfoamwiki.net/index.php/Ho...rocMultiregion Based on the second option I put together a bash script which will allow you to open multiple region cases using a single command, e.g. paraFoamMultiMesh . conjugateHeat solid1 fluid1 solid2 ... The script is for OF version 1.4.1-dev with paraview 2.4.4 but it might save you some time or at least give you a starting point. |
Can't open Case and DATA File | chern | FLUENT | 6 | April 19, 2016 12:08 |
Performance of GGI case in parallel | hannes | OpenFOAM Running, Solving & CFD | 26 | August 3, 2011 04:07 |
[OpenFOAM] Paraview in Prallel (server-client) | prapanj | ParaView | 11 | September 24, 2010 08:12 |
icoFsiFoam case needed | vivekcfd | OpenFOAM | 1 | May 6, 2009 14:41 |
[OpenFOAM] ParaFoam cannot open icoFoam/cavity case | Bob | ParaView | 1 | April 2, 2009 05:34 |
