problem when running icoFoam on a complex shape flow field
Old   May 20, 2009, 23:18
Default problem when running icoFoam on a complex shape flow field
xianghong wu
wendywu is on a distinguished road
I am asking a question about running icoFoam on a complex shaped 3D flow field(I sHM it ). when I run icoFoam on the case, I got the following information
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/xhw/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/xhw/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7ffe400]
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/xhw/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::Istream&) in "/home/xhw/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam"
#5 Foam::lduMatrix::solverPerformance Foam::solve<Foam::Vector<double> >(Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > const&) in "/home/xhw/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam"
#6 main in "/home/xhw/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam"
#7 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#8 _start in "/home/xhw/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam"
Floating point exception
To keep the courant number <=1 , I defined the deltaT=0.005 according to velocity , cell size , But the courant number becomes
Courant Number mean: 1.15107e+98 max: 1.04117e+102
when T=0.08
the attachment is the case files
Anybody can give me some hints? Thank you very much for any help.
Wendy
wendywu is offline   Reply With Quote
Old   May 21, 2009, 00:40
xianghong wu
This is the attachment. I can not upload constant folder because is too big size.
Thank you.
Wendy
File Type: gz 0.tar.gz (998 Bytes, 5 views)
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
Problem: text commands to initialize flow field Carolyn Jacobs FLUENT 0 April 10, 2007 06:03
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
