Problem with naca mesh
Old   May 20, 2009, 20:10
Default Problem with naca mesh
Jose
josee is on a distinguished road
Hello everyone, I would like to know why I am having trouble with a Mesh I've imported from ICEM using fluentMeshToFoam. It seems the mesh doesn't have problems but after running checkMesh a failed mesh check message appears. I have used OpenFOAM for about five months so I am still learning. Any advice I'd appreciate! This is the checkmesh file:
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
internal points: 0
faces: 252531
internal faces: 125253
cells: 62964
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 62964
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
INLET 118 238 ok (non-closed singly connected)
AIRFOIL 516 1032 ok (non-closed singly connected)
TOP 259 520 ok (non-closed singly connected)
OUTLET 198 398 ok (non-closed singly connected)
AIR 125928 127278 ok (non-closed singly connected)
BOTTOM 259 520 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-7.99908 -8 0) (20 8 0.25)
Mesh (non-empty) directions (0 0 0)
Mesh (non-empty, non-wedge) dimensions 0
***Number of edges not aligned with or perpendicular to non-empty directions: 252688
<<Writing 127278 points on non-aligned edges to set nonAlignedEdges
Boundary openness (4.6997e-21 -1.41369e-19 -8.49101e-19) OK.
Max cell openness = 2.61622e-16 OK.
Max aspect ratio = 337.785 OK.
Minumum face area = 2.24974e-06. Maximum face area = 0.767972. Face area magnitudes OK.
Min volume = 4.49947e-07. Max volume = 0.153594. Total volume = 84.0793. Cell volumes OK.
Mesh non-orthogonality Max: 47.7005 average: 6.55558
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.385209 OK.
Failed 1 mesh checks.
End
josee is offline   Reply With Quote
Old   May 4, 2010, 07:29
Default Did you manage to solve this problem?
Vasu
milleniumrider is on a distinguished road
Hi Jose,
I'm importing a mesh from ICEM as well using fluent3DMeshToFoam and have the same error message upon running checkMesh, I wanted to ask if you managed to solve the problem. And if so, could you give me some help as to how you did it?
Thank you for your time.
Best,
Vasu
milleniumrider is offline   Reply With Quote
Old   May 4, 2010, 13:10
Default mesh to fluent
Jose
Jose Villegas is on a distinguished road
I stopped using OpenFOAM, I could not find a solution to that problem, it seems it was a problem with the mesh orientation.
Jose Villegas is offline   Reply With Quote
Old   May 4, 2010, 14:04
Default Ok Thanks anyway for the reply :)
Vasu
Hey Jose,
That's too bad, thanks for the reply.
Can I just ask if you were using an axi-symmetric case by any chance? And what solver did you use finally if you dont mind me asking?
Best,
Vasu
checkmesh, naca, openfoam
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
mesh generation problem Ellen FLUENT 7 February 18, 2009 22:20
The problem with GAMBIT - using two mesh sizes. Owen FLUENT 2 June 22, 2005 06:16
mesh control problem TUM CFX 4 July 27, 2001 17:17
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 21:26
