May 19, 2009, 12:38 |
Premixed laminar flame
Chris
Rep Power: 17 |
I have to do simulations of PREMIXED laminar flames with detailed chemistry. Right now I am in the phase of having to choose a suitable code. The possibility to have access to the source code and to implement own models makes OpenFoam very attractive. Has anybody experience with the simulation of premixed laminar flames with OpenFoam (the chemistry is supplied in Chemkin format)? Is it possible to use ReactingFoam? Thanks |
May 23, 2009, 04:50 |
Karl-Johan Nogenmyr
Rep Power: 21 |
I think reactingFoam can be a good start... I use a modified version of it for LES+reduced chemitry (stratified premixed)... works great!
June 10, 2009, 10:00 |
thx
Chris
Rep Power: 17 |
ok thanks,
i will start working with reacting foam |
July 26, 2009, 23:04 |
Rep Power: 17 |
Kalle: I've been looking for the Arrhenius equation definitions for ReactingFoam because I also want to do a laminar premixed flame (for now, H2+O2+Ar) - but I cannot find them. Can you help? Thanks! Patti
July 28, 2009, 00:07 |
Lu,Y.
I vaguely remember that there has been a utility (or function?) in OpenFOAM 1.5 that computes premixed laminar flame speed. If that is all that you want, why not try it?
August 4, 2009, 03:03 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Patti: Now, you've got me a bit. I also searched as you some time ago.
Please start by having a look in file ChemistryModel.C at line 572ff. There is the solve function which is called by chemistry.H (in the reactingFoam solver). Using the OpenFOAM Doxygen is convenient: http://foam.sourceforge.net/doc/Doxy...ce.html#l00563 There you can see that the line; 00626 mixture += (c[i]/cTot)*specieThermo_[i]; does the actual increase/decrease of each species. The important term here is 'specieThermo_[i]'. If I got it right (I'm not 100%) how this one is calculated depends on your settings in the thermodynamicProperties dictionary. But how the settings there affects the reactingFoam at runtime is unfortunately beyond my C++ knowledge... However... if you start from the reactingFoam tutorial http://openfoamwiki.net/index.php/Tu..._firstTutorial and modify the chemical mechanism (and of course mesh+BC's) in the /chemkin directory I think you should be good off to do your laminar flame. Good luck, Kalle |
August 4, 2009, 11:42 |
Rep Power: 17 |
Thanks, Kallie! That's the first good news I've heard so far... I was actually talking to the OF folks and they haven't implemented the CHEMKIN-II style diffusivities, which is critical for low-pressure flames. I am thinking of asking my company to sponsor that, since I have no C++ knowledge!
August 4, 2009, 20:26 |
Karl-Johan Nogenmyr
Rep Power: 21 |
I see... You may also have a look at an OpenFOAM+Cantera project going on:
http://www.opensourcecfd.com/confere...haiderRehm.pdf I dont know details about Cantera, but it may provide the diffusivities you need. If you try and get it working, please post a note on that... would be interesting. Kalle |
detailed chemistry, flame, laminar, premixed |
Combustion in a flame premixed & laminar | Quasimodo | FLUENT | 0 | December 5, 2007 08:06 |
premixed laminar flame | JCRC | FLUENT | 2 | July 25, 2006 05:33 |
laminar premixed flame | Paul Lee | CFX | 1 | September 14, 2005 06:37 |
Simulating laminar premixed flame | Subhash | FLUENT | 0 | August 17, 2004 00:46 |
steady/unsteady better to laminar premixed flame? | Harry Qiu | FLUENT | 0 | March 27, 2001 02:52 |
