Problems with extracting OpenFOAM
Old   May 15, 2009, 17:46
Default Problems with extracting OpenFOAM
JohanOlivier is on a distinguished road
Good day, i have downloaded the installation files for OpenFOAM (32 bit linux version) but i am not able to extract them. I get a message "An error occured while extracting files." I'm running Ubuntu 9.04... Has anyone some suggestions on what I'm doing wrong?
JohanOlivier is offline   Reply With Quote
Old   May 22, 2009, 00:34
Default how to extract openfoam files
Nurye
carlos is on a distinguished road
Hi Guys. I have encountered the same problem too... I'm also running Ubuntu 9.04...I appreciate if someone gives me tips how to extract openfoam files...Thanks
carlos is offline   Reply With Quote
Old   May 22, 2009, 05:51
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Have you tried the following in a terminal?
tar xzf <file>
santos is offline   Reply With Quote
Old   May 22, 2009, 09:02
Ulrich Heck
ulli is on a distinguished road
For Ubuntu users, I strongly recommend to use Jure's installation script:
http://www.cfd-online.com/OpenFOAM_D...es/1/8918.html
This really works excellent.
Ulrich
ulli is offline   Reply With Quote
Old   May 22, 2009, 12:38
Nurye
tar xzf <file>
Yes, i have tried it but it shows the following error message:
"an error occurred while extracting files"
I will go through what ulli has recommended me and let you know what the result.
thanks guys for your help
Old   May 22, 2009, 16:38
santos's Avatar
Jose Luis Santos
I suspect you have a bad file, probably because of an incomplete download. The Ubuntu script automates the installation for you, but I think it wont help you in your problem.
Regards,
Jose Santos
Old   May 22, 2009, 18:02
I've tried the terminal and and works. I ran foamInstallationTest after the installation and everything seems ok except for the following message..
Action Result Crit
Pinging_johano-laptop Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
OpenFOAM 1.5 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
Critical systems ok.
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
I'm working on a stand-alone computer, so i dont know if the "Fatal Error" is relevant.... ?
When I try to run the cavity tutorial in icoFoam, i get the following error when running blockMesh:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : blockMesh
Date : May 22 2009
Time : 23:01:49
Host : johano-laptop
PID : 15708
Case : /home/johano/OpenFOAM/johano-1.5/FOAM_RUN/tutorials/icoFoam/cavity/constant/polyMesh
nProcs : 1
Create time
cannot open file
file: /home/johano/OpenFOAM/johano-1.5/FOAM_RUN/tutorials/icoFoam/cavity/constant/polyMesh/system/controlDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
Anyone knows what the problem might be?
Thank you.
Old   May 23, 2009, 02:59
Nurye
Dear JohanOlivier,
I know you had a problem on extracting OpenFOAM-1.5 files. Can you please tell me how you extracted the files and install them on ubuntu 9.04?
Regards
Carlos
Old   May 23, 2009, 03:06
Nurye
Regards,
Jose Santos
May be. I have downloaded the openfoam files on window xp. i will download all the files again on ubuntu 9.04 and try to extract them. thank you
Regards,
Old   May 24, 2009, 16:46
akidess's Avatar
Anton Kidess
Hello Johan,
it looks like something is wrong with your paths. Why is there FOAM_RUN in your path? Also, you might be calling blockMesh in the wrong directory. You have to run it in the base directory of your case, not in constant/polyMesh/.
Did you copy the tutorial from /home/johano/OpenFOAM/OpenFOAM-1.5/tutorials/icoFoam/ to /home/johano/OpenFOAM/johano-1.5/run/icoFoam/ ?
Anton
Old   May 24, 2009, 16:51
Hi Carlos,
I used the command tar xzf <file> but make sure you create a directory OpenFOAM in $HOME/<user>. The directory structure in my case was $HOME/johano/OpenFOAM Then copy the downloaded files to this directory and use the command tar xzf<file> to extract the files. This should work...hopefully.
regards
Johan
[Commercial meshers] Boundary condition problems (OpenFOAM) Milos OpenFOAM Meshing & Mesh Conversion 13 October 13, 2016 20:58
OpenFoam for heat transport problems Martin Lorenz (Lorenz) OpenFOAM Running, Solving & CFD 16 March 18, 2009 04:05
[General] OpenFoam - problems MateuszZb ParaView 8 July 21, 2008 17:16
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
