Problem with cyclic boundaries in Openfoam 1.5 |
January 30, 2012, 10:26 |
#21 | |
Aqua
Rep Power: 15 |
I created my mesh by blockMesh, snappyHexmesh, but still have the problem "face 391 area does not match neighbour 791 by 0.0136179% -- possible face ordering problem." I also set writeprecision as 10.. Could you please give some suggestion? Thank you so much! Aqua |
March 6, 2012, 19:21 |
#22 |
Vishal Achasrya
Rep Power: 14 |
Dear aqua,
In "createPatchDict" file from the applications/utilities/mesh/manipulation folder, you will see the following... // 2. Correct incorrect cyclic: // This will usually fail upon loading: // "face 0 area does not match neighbour 2 by 0.0100005%" // " -- possible face ordering problem." // - in polyMesh/boundary file: // - loosen matchTolerance of all cyclics to get case to load // - or change patch type from 'cyclic' to 'patch' // and regenerate cyclic as above So, you can loosen matchTolerance of your cyclics to get it to work or change the patch type to patch from cyclic and use createPatch to make your cyclic. Hope this helps, let me know. |
March 7, 2012, 04:38 |
#23 | |
Aqua
Rep Power: 15 |
Thank you so much for your kind reply. I knew the matchTolerance, so I tried to give it a big value, even 3. but it still didn't work. For me the interesting thing was: I could create the cyclic in OF2.0 with a matchTolerance of 0.001; But I couldn't create the cyclic in OF 1.6-ext even the matchTolerance was 3... So I assumed that OF1.6ext has something not that right... cheers! Aqua |
January 23, 2013, 09:25 |
#24 |
ali jafari
Rep Power: 14 |
hi
I found out that PointWise dont need these steps such as Gambit. is this true ? |
April 18, 2013, 08:31 |
problem with fan and createPatch
#25 |
Jose
Rep Power: 14 |
Hi everyone,
I am having trouble dealing with cyclic boundary conditions, namely with the fan boundary condition since I want to simulate a jump pressure between two parts of my system. First I will describe a little bit my case. I have two different tubes. At the outlet of the first tube I want to simulate a pressure drop of 0,2bar before the flow continues through the other tube (see picture 1 attached). My problem is that the patches "a and b" do not match each other ( the error says "area does not match neighbour 2520 by...") after mesh-conversion to OF. Therefore the createPatch utility must be run. The process IŽve carried out so far is: 1. Mesh-generation/export with ANSYS 2. Coversion with fluent3DMEshtoFOAM 3. Creation of createPatchDict to combine the separated periodic patches to one (a und b to a) 4. Run createPatch utility. Folder /1/polyMesh is created 5. Copy of the contents of /1/polyMesh to constant/polymesh/ 6. Change wall type to cyclic for the new created "a" patch 7. Now I need the NeighbourPatch for the new created "a" patch... What should I do here? Fabian says that createPatch directory should be changed and then createPatch re-run again. I do know how this new createPatchDict should look like... I mean, what should be written there in order to get the right second patch? Another way I came up with would be to use cyclicAMIs instead of cyclics one. On this way, the createPatch-process would be avoided but then the fan b.c. could not be used (the error "attempt to cast type cyclicAMI to type cyclic" appears).. Other possibility would be to use groovyBC... but I am not sure about it. I am running out of ideas anklöäd I would really appreciate any kind of help in this topic. I wish you a nice Thursday, José. |
April 22, 2013, 07:54 |
#26 |
maddalena
Rep Power: 23 |
Hi Josè. What OF version are you using? you did not mention it in your post.
mad |
April 22, 2013, 12:45 |
#27 |
Jose
Rep Power: 14 |
Hi Maddalena,
I am using OF 2.1.1. Regards, José. |
April 22, 2013, 13:19 |
#28 |
maddalena
Rep Power: 23 |
Then this is not the right place where to look for infos... Cyclic definition has changed since OF 2.1. You can find something more here: http://www.cfd-online.com/Forums/ope...aries-21x.html
April 23, 2013, 08:35 |
#29 |
Jose
Rep Power: 14 |
Thank you Maddalena!
I went through this post (and the post inside it) and I am still having some trouble after modifying my case. I will be post my case there. I will be very grateful if you could take a look at it. Greets, José. |
April 12, 2014, 05:33 |
problem in creation of Cyclic Boundaries
#30 | |
Rep Power: 13 |
I have followed the steps mentioned above to create cyclic boundaries but i am getting following error Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1$ createPatch /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : createPatch Date : Apr 12 2014 Time : 14:50:47 Host : BMH301562 PID : 30912 Case : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading createPatchDict. Create polyMesh for time = 0 Adding new patch ROTOR_PER_1 as patch 20 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle 32.727272; } Adding new patch ROTOR_PER_2 as patch 21 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle -32.727272; } Adding new patch UPS_PER_1 as patch 22 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle 32.727272; } Adding new patch UPS_PER_2 as patch 23 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle -32.727272; } Adding new patch DWS_PER_1 as patch 24 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle 32.727272; } Adding new patch DWS_PER_2 as patch 25 from { type cyclic; transform rotational; rotationAxis ( 0 0 1 ); rotationCentre ( -2.411051e-05 1.067036e-06 0 ); rotationAngle -32.727272; } Moving faces from patch PERIODIC1 to patch 20 Moving faces from patch PERIODIC2 to patch 21 Moving faces from patch PER1_UPS to patch 22 Moving faces from patch PER2_UPS to patch 23 Moving faces from patch PER1_DWS to patch 24 Moving faces from patch PER2_DWS to patch 25 Doing topology modification to order faces. cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_1_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_1_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_1_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_1_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch ROTOR_PER_1 gets decomposed in two zones ofinequal size: 4216 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_2_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_2_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_2_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/ROTOR_PER_2_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch ROTOR_PER_2 gets decomposed in two zones ofinequal size: 4216 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_1_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_1_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_1_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_1_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch UPS_PER_1 gets decomposed in two zones ofinequal size: 1302 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_2_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_2_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_2_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/UPS_PER_2_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch UPS_PER_2 gets decomposed in two zones ofinequal size: 1302 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_1_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_1_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_1_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_1_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch DWS_PER_1 gets decomposed in two zones ofinequal size: 2728 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_2_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_2_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_2_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_Passage_cyclic_1/DWS_PER_2_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 567 Patch DWS_PER_2 gets decomposed in two zones ofinequal size: 2728 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! From function void polyMesh::initMesh() in file meshes/polyMesh/polyMeshInitMesh.C at line 82 Truncating neighbour list at 1813845 for backward compatibility --> FOAM FATAL ERROR: face 2107 area does not match neighbour 4215 by 152.364% -- possible face ordering problem. patch:ROTOR_PER_1 my area:3.03748e-08 neighbour area:4.10639e-09 matching tolerance:0.0001 Mesh face:1871106 vertices:4((0.00653842 -0.00288073 0.0114033) (0.00657244 -0.00290527 0.0114147) (0.00637971 -0.0029294 0.0120858) (0.00634532 -0.00290463 0.0120763)) Neighbour face:1873214 vertices:4((0.0147695 -0.00953986 0.0184802) (0.0147895 -0.00955175 0.0184814) (0.0147846 -0.00955927 0.0186456) (0.0147618 -0.00954592 0.0186455)) Other errors also exist, only the largest is reported. Please rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 294. FOAM aborting Aborted (core dumped) |
June 4, 2014, 04:03 |
problems with Cyclic and simpleSRFFoam in OF-ext 3.0
#31 |
Rep Power: 13 |
I think that I have a problem with cyclic interface. I'm running a pump blade passage in simpleSRFFoam in foam-extend 3.0 The mesh is fully hexahedral made with a commercial software and the cyclic interface has been created with create patch. The checkMesh is OK and my BC are Boundary Code:
inlet { type patch; } outlet { type patch; } wall { type wall; } cyclic { type cyclic; nFaces 3108; startFace 114735; featureCos 0.9; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); rotationAngle 51.42857143; } Code:
wall { type fixedValue; value uniform (0 0 0); } inlet { type SRFVelocity; inletValue uniform (0 0 6); relative yes; value uniform (0 0 0); } outlet { type zeroGradient; } cyclic { type cyclic; } Code:
wall { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } cyclic { type cyclic; } the simulation diverges really quickly: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0-83767105dac9 Exec : simpleSRFFoam Date : Jun 03 2014 Time : 18:19:34 Host : ale-XPS-M1530 PID : 9432 CtrlDict : /home/ale/OpenFOAM/OpenFOAM-extend-3.0/etc/controlDict Case : /home/ale/OpenFOAM/ale-3.0/run/impeller_Ale_noPrism_Ext3 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1 Reading field p Reading field Urel Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; Cmu 0.09; } Creating SRF model Selecting SRFModel rpm Starting time loop Time = 2 DILUPBiCG: Solving for Urelx, Initial residual = 1, Final residual = 2.79903e-05, No Iterations 4 DILUPBiCG: Solving for Urely, Initial residual = 1, Final residual = 6.0469e-05, No Iterations 4 DILUPBiCG: Solving for Urelz, Initial residual = 1, Final residual = 4.8147e-05, No Iterations 5 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.000950259, No Iterations 175 DICPCG: Solving for p, Initial residual = 0.110069, Final residual = 9.65805e-05, No Iterations 169 DICPCG: Solving for p, Initial residual = 0.10585, Final residual = 9.1452e-05, No Iterations 168 time step continuity errors : sum local = 0.094795, global = 0.000555515, cumulative = 0.000555515 DILUPBiCG: Solving for omega, Initial residual = 0.0533918, Final residual = 7.19262e-05, No Iterations 1 bounding omega, min: -0.012838 max: 670192 average: 3721.31 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.65011e-05, No Iterations 2 ExecutionTime = 1.88 s ClockTime = 2 s Time = 3 DILUPBiCG: Solving for Urelx, Initial residual = 0.999251, Final residual = 3.87368e-05, No Iterations 4 DILUPBiCG: Solving for Urely, Initial residual = 0.999369, Final residual = 1.88171e-05, No Iterations 4 DILUPBiCG: Solving for Urelz, Initial residual = 0.998988, Final residual = 8.33906e-05, No Iterations 22 DICPCG: Solving for p, Initial residual = 0.08725, Final residual = 8.06568e-05, No Iterations 180 DICPCG: Solving for p, Initial residual = 0.0148115, Final residual = 1.42158e-05, No Iterations 184 DICPCG: Solving for p, Initial residual = 0.0181394, Final residual = 1.75546e-05, No Iterations 181 time step continuity errors : sum local = 2133.01, global = 18.4662, cumulative = 18.4667 DILUPBiCG: Solving for omega, Initial residual = 0.999924, Final residual = 0.00080576, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.992957, Final residual = 5.56803e-05, No Iterations 2 ExecutionTime = 3.36 s ClockTime = 4 s Time = 4 DILUPBiCG: Solving for Urelx, Initial residual = 0.0678987, Final residual = 1.90842e+15, No Iterations 1000 DILUPBiCG: Solving for Urely, Initial residual = 1, Final residual = 0.101565, No Iterations 1000 DILUPBiCG: Solving for Urelz, Initial residual = 0.0626209, Final residual = 0.000292353, No Iterations 1000 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.000836971, No Iterations 186 DICPCG: Solving for p, Initial residual = 0.030226, Final residual = 2.58344e-05, No Iterations 186 DICPCG: Solving for p, Initial residual = 0.0220053, Final residual = 1.96485e-05, No Iterations 184 time step continuity errors : sum local = 5.59353e+19, global = 3.3388e+17, cumulative = 3.3388e+17 DILUPBiCG: Solving for omega, Initial residual = 1, Final residual = 0.0018931, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.094051, Final residual = 1.21682e-06, No Iterations 3 ExecutionTime = 17.64 s ClockTime = 18 s Time = 5 DILUPBiCG: Solving for Urelx, Initial residual = 0.0742309, Final residual = 53801.3, No Iterations 1000 DILUPBiCG: Solving for Urely, Initial residual = 0.999454, Final residual = 7.77307, No Iterations 1000 DILUPBiCG: Solving for Urelz, Initial residual = 0.0590893, Final residual = 0.000159322, No Iterations 1000 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.000875957, No Iterations 200 DICPCG: Solving for p, Initial residual = 0.0590136, Final residual = 5.01017e-05, No Iterations 200 DICPCG: Solving for p, Initial residual = 0.0255778, Final residual = 2.29427e-05, No Iterations 194 time step continuity errors : sum local = 1.48812e+25, global = -9.59329e+22, cumulative = -9.59326e+22 DILUPBiCG: Solving for omega, Initial residual = 0.999996, Final residual = 0.00330149, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0735992, Final residual = 3.5885e-07, No Iterations 3 ExecutionTime = 31.99 s ClockTime = 32 s Time = 34 Floating point exception (core dumped) Do you have any suggestion? Regards, Ale |
June 4, 2014, 04:17 |
#32 |
Rep Power: 13 |
Floating point error is bad because you can not get and error which is occurring while solving the problem. Few things to check... 1. How many no of passages you have ( according to your input i can see there are 7 passages ) if not please correct accordingly. 2. Check your initial values for all fields are appropriate . 3. Most importantly your cyclic definition in commercial package while meshing should be very appropriate i.e point to point connection between the nodes. Regards, Sangamesh Hosur |
June 4, 2014, 04:38 |
#33 |
Rep Power: 13 |
Thank you for your reply.
1: The number of blade passage is correct 2: I think they are. But I will check it again. 3: The meshes on the cyclic boundary is conformal. Seeing how fast it's diverging I think that the error has to be something evident but I couldn't find it yet. |
June 4, 2014, 04:45 |
#34 |
Rep Power: 13 |
Check your k-omega BC's. Which are the major culprits for this floating point error . by the way how have you evaluated k-omega values ? Regards, Sangamesh Hosur |
June 4, 2014, 11:17 |
#35 |
Rep Power: 13 |
the first time I calculated my k omega and epsilon with standard formula using the inlet velocity, the second time I took it from the results of the simulation that I'm using as benchmark and then I tried to run it as laminar with a reduced velocity but the results don't change that much. While setting the cyclic BC as wall the simulation runs with both sets of turbulent BC.
for example my k dictionary looks like: Code:
boundaryField { wall { type kqRWallFunction; value uniform 0.6; } inlet { type fixedValue; value uniform 0.15; } outlet { type zeroGradient; } cyclic { type cyclic; value uniform 0.15; } } |
June 6, 2014, 12:02 |
#36 |
Rep Power: 13 |
Yesterday I ran the complete impeller with the same BC and initial field and the results are fine, so I'm sure that my problem is related to cyclic BC.
I found a topic about problems of cyclic BCs applied to curved surface. http://www.cfd-online.com/Forums/ope...-boundary.html Mattijs "Hi Håkan, cyclics have to be planar for automatic matching (couplePatches, createPatch) to work since both transformation tensor and face-face correspondence have to be determined. If they are non-planar you'll have to get your mesh generator to output the patch faces in the correct order. " As far as I know the new definition of the cyclic BC (OF 2.1x), don't have anymore this limitation. I saw that the utility createPatch in OF-ext-3.0 is taken from OF-ext-1.6 and if I'm not wrong it uses the old cyclic definition, consequently I start to think that it can be the reason why my simulation diverges. Am I wrong? Can you suggest me how can I check if my cells are in the correct order? Regards, Alessandro |
January 7, 2015, 00:31 |
#37 |
Muhammad Omer Mughal
Rep Power: 16 |
Hi
I am using terrain block mesher to mesh my terrain .The problem with this tool is that it cannot generate cyclic boundary conditions.I therefore had to use the createPatchDict utlity to create the cyclic patches. the problem is that I have north,south east west patches as neighbours and I cannot combine them into two as you did for your case as each. I am attaching the boundary and createPatchDict and would appreciate if you can kindly suggest a solution to my problem. |
OpenFOAM 1.5 installation on OpenSUSE 11.0 | bigphil | OpenFOAM Installation | 16 | April 29, 2009 06:28 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Solving a Riemann problem in OpenFoam | srinath | OpenFOAM Running, Solving & CFD | 2 | July 15, 2008 09:34 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Riemann problem at boundaries | K. I. Chan | Main CFD Forum | 0 | December 10, 2000 22:56 |
