Solidification in OpenFoam
Old   April 28, 2009, 05:49
Default Solidification in OpenFoam
Luke Christ
luke.christ is on a distinguished road
Dear all,
I'm going to use OpenFoam for simulating a continuous casting problem. I'm completely new to OpenFoam, and it seems to me that there is not any solidification model in OpenFoam. Should I create solidification model myself?
As my case is continuous casting, I should consider a pull velocity for solid phase, too. Is it possible without great difficulties in OpenFoam?
I will be thankful for you reply.
luke.christ is offline   Reply With Quote
Old   January 30, 2013, 02:38
Default Updates
hawkeye321 is an unknown quantity at this point
Are you still interested in solidification in OpenFOAM?
hawkeye321 is offline   Reply With Quote
Old   May 3, 2013, 11:25
Mac007's Avatar
Mac
Mac007 is on a distinguished road
Hello
I'm newbie with OpenFOAM, but I'm interested to model solidification of steel. If i have well understood, there is no built-in solver? Do you know where I can find one?
Regards
Mac007 is offline   Reply With Quote
Old   May 3, 2013, 12:00
Default solidification problem
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
In the thread http://www.cfd-online.com/Forums/ope...g-problem.html you can find several solvers for melting and solidification using the enthalpy method and the enthalpy porosity method.
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   May 6, 2013, 02:45
Mac007's Avatar
Mac
Thanks a lot
Old   June 9, 2013, 17:02
Default Explanation for terms in TEqn.H?
einat
einatlev is on a distinguished road
Hello all!
I am trying to use meltFOAM for my project on solidification of lavas. I am trying to understand the terms appearing in TEqn.H. I identified the dT/dt, advection and diffusion terms, and then see terms that involve latent heat, and what I figure is some sort of a melt fraction term, but I don't understand the details -- what is the exponent, where did all the "4" factors come from, etc.?
Here's the code:
fvScalarMatrix TEqn
fvm::ddt(cp, T)
+ fvm::div(phi*fvc::interpolate(cp), T)
+ hs*4.0*exp(-pow(4.0*(T-Tmelt)/(Tl-Ts),2))/Foam::sqrt(pi)/(Tl-Ts)*fvm::ddt(T)
+ hs*4.0*exp(-pow(4.0*(T-Tmelt)/(Tl-Ts),2))/Foam::sqrt(pi)/(Tl-Ts)*(U & fvc::grad(T))
- fvm::laplacian(lambda/rho, T)
Thanks!!!
einatlev is offline   Reply With Quote
Old   June 11, 2013, 09:58
Fabian Roesler
Have a look into my paper on the solver:
F. Rösler, D. Brüggemann (2011): Shell-and-tube type latent heat thermal energy storage: numerical analysis and comparison with experiments. Heat and Mass Transfer, Vol. 47 Issue 8 , 1027-1033, DOI: 10.1007/s00231-011-0866-9
http://www.springerlink.com/content/b1tp01k2u7q8j432/
Keep in mind that the solver does not account for non-linearity like the linear source method by Voller. The erfMeltSolver just reduces the non-linearity effects in the energy conservation equation. For simple problems, the results converge with a very small error for the energy conservation. With increasing convective transport, the error increases and some iteration to account for the non-linearity have to be performed.
In my previous work, I use a linear liquid fraction function and the linear source method proposed by Voller.
Regards
Fabian
Old   June 11, 2013, 12:15
einat
Excellent paper Fabian! Thanks for pointing it. Just what I needed.
Old   July 6, 2013, 03:24
Default Stefan problem
Vjoess
dinesh is on a distinguished road
Sir
i am also trying to analysize the phase change problem.I want to know is it possible to do it on Fluent and if yes which solver /model i should go for.
thanks
Regards
Fabian
dinesh is offline   Reply With Quote
Old   July 10, 2013, 05:38
Fabian Roesler
Hi dinesh
Yes, Fluent offers an Enthalpy-Porosity-Method for simulation of solid/liquid phase change. Unfortunately I never used Fluent for such simulations so go on and find out yourself. Good luck.
Regards
Fabian
Old   July 20, 2013, 12:59
Mojtaba
r.mojtaba is on a distinguished road
Originally Posted by dinesh View Post
Sir
thanks
Hello danish.
As Fabian said, FLUENT can solve Solidification/Melting problems. I myself tested and validated the solver for my thesis. There are excellent tutorial and theory materials from Ansys Fluent. Using Google, you may find them with no problem.
Have fun!
r.mojtaba is offline   Reply With Quote
Old   August 30, 2013, 06:18
Vjoess
Originally Posted by r.mojtaba View Post
Hello danish.
Have fun!
I found from literature but there is contradiction.
Ref "H. Shmueli et al. / International Journal of Heat and Mass Transfer 53 (2010) 4082–4091" this paper says "page number 4086 says: As for the pressure discretization, only PRESTO!and Body-Force-Weighted schemes are available for the VOF and mixture multiphase models." Does this means that multiphase has to be used for my case. Enabling this i find that courant number can be inserted which the paper says to be kept around 0.5. what about the phase 1 and phase 2. see this post by me which flotus replied on 11july
Ref "http://www.cfd-online.com/Forums/system-analysis/120322-stefan-problem.html#post439934"
eagerly waiting for the reply
Old   August 30, 2013, 22:59
Mojtaba
So you have two zones, one is a closed container with PCM solidification and the other with a fluid flow around container, Right? If so, you don't need multiphase model at all. Using Fluent, during the solidification there is only one phase (fluid). To model solid zone (which is not really a solid phase in this model), Fluent adds a huge artificial viscosity to the solid zone to prevent flow on it. In this way, there is no need to define two phase flow.
I think this open access paper can help you:
A Numerical Study on Time-Dependent Melting and Deformation Processes of Phase Change Material (PCM) Induced by Localized Thermal Input
Old   September 1, 2013, 09:34
Vjoess
I went through this paper it refers on page no 529 TO REPRESENT THE FREE SURFACE OF THE MELTING REGION ADJACENT TO THE GAS PHASE, VOF METHOD IS USED. Now in fluent this VOF is under the menu of multiphase model. so plz clarify me? how can i find the melted region profile?
Old   September 3, 2013, 02:30
Mojtaba
You didn't answer my question about whether the solidification zone is a fully filled container or not? If there is no gas in contact, using VOF is not necessary at all.
When you plot the contour of liquid fraction (F) the melt-solid (or melt-gas) interface can obviously be seen and extract. Refer to Kim's paper, Fig. 9 to 11.
Old   September 3, 2013, 03:53
Vjoess
I am handling without air case.
Plz see the plot i got
https://www.dropbox.com/s/gg3mqyum1u3mx5z/frac4000s.png
How can i extract the data regarding the anount or percent of solid melted/or mushy zone volume.
thanks
Old   September 3, 2013, 12:15
Mojtaba
How can i extract the data regarding the amount or percent of solid melted/or mushy zone volume.
You need to calculate volume integral of liquid fraction. Fluent can do this by some simple Clicks. Do as below:
-From Menu Bar, go to Report and choose Volume Integrals... to open Volume Integral Window.
-In Volume Integrals Window:
--Choose Fluid (or whatever the solidification zone's name is) from right menu (Cell Zones),
--Choose Volume Integral from left menu (Report Type),
--Under Field Variable, select Solidification/Melting... and then Liquid Fraction,
--Click Compute button... and it's done!
Good Luck
Old   September 4, 2013, 09:56
Vjoess
Good Luck
thankyou very much for the support you provided.
Can you plz tell me about the discretization method. I used SIMPLE method with PRESTO scheme (without gravity being aplied) i got some result. Now i am using PISO with Body Force weighted with gravity added slowly from 1m/s2 to 9.81 m/s2 (as recommended by some user). I run the simulation for some time and then i get divergence either in epsilon or( x y z componenet of velocity) can you suggest some way to overcome this.
Old   September 4, 2013, 11:01
Mojtaba
What are Ra and Pr numbers related to your simulation?
I've done an unsteady simulation of melting Gallium in a 2D cavity with Ra=2.2x10^5. I used SIMPLE for pressure-velocity coupling, PRESTO! for pressure discretization and SST k-w for turbulence modeling. You can obtain a good convergence with a small enough time step and fine enough grid.
If the convergence problem is still bothering, bring up more info about your simulation.
Old   September 4, 2013, 15:03
Vjoess
With SIMPLE and PRESTO i also got the convergence. But with PISO and Body Force weighted i am not getting the convergence, I am refering" H Shmueli et al /IJHMT 53(2010) 4082-4091 where he is comparing the different schemes(page no 4085).
Regarding Pr and Ra i have not calculated. My hot water flow velocity is 0.1m/s at 350 K which is used to melt parafin wax which initially is at 293K and melting temperature is 313-316K. Hot fluid flows inside while the outer cylinder(0.6m dia 1m length) is enclosing the wax.
continuous casting
Solidification simulation with OpenFOAM James OpenFOAM 6 September 8, 2024 11:13
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
