A free surface problem
Old   April 27, 2009, 00:30
Default A free surface problem
crammer008
crammer008 is on a distinguished road
Dear all,
I am a newbie. I'd like to simulate the following simple case. Would you please tell me where I can find a similar tutorial case to learn the modelling.
The tested case is a 2D rectangular tank which is partially filled with water and will move with a sinusoidal signal. The measured data is the pressure response at a certain point and free-surface elevation at a certain vertical position. A laminar model is preferred for the case.
Many thanks!
Crammer008
crammer008 is offline   Reply With Quote
Old   April 27, 2009, 10:33
Kent Wardle
kwardle is on a distinguished road
Take a look at interDyMFoam, this should be what you need. There are several tutorials available for sloshing tanks as well to help you get started.
kwardle is offline   Reply With Quote
Old   April 27, 2009, 22:41
crammer008
Dear Kwardle,
Thanks a lot for your great help
Best regards,
LUO Chao
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 17:50
Free Surface Position Jennifer CFX 3 November 17, 2008 02:51
Free surface modelling under CFX 4 Dahong CFX 2 June 23, 2002 00:07
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 18:32
