Hi Foamers,
I'm using the latest svn with a GGI interface and I noticed that when I run the vorticity tool on the case and then visualize in paraFoam, the vorticty at the interface is really weird (high values all along the interface), for almost all my runs.. However, the flow field around the interface is fine in terms of pressure, velocity, and vorticty... Could that be an issue with the vorticity tool when used with GGI? Thanks for your feedback, -Louis |
Hai Yu
Rep Power: 17 ![]() |
hallo, louisgag
according to me, GGI is already much better on this than Sliding Interface. while in Sliding Interface, I always observe this problem. How many faces have you used on the interface? and deltaT is how much? Regards. |
Hi Yuhai,
I used 200 faces on my interface (it is 2D) and the resolution is similar to my boundary layer resolution. As for deltaT, i let it vary with a max courant number of 0.5. (So, deltaT is roughly 1e-05 ty for the feedback, -Louis |
Pavan
I also had a similar problem with the solution at the interface. I had a spatial discontinuity though, no spikes or anything. It looked as if the solution on the outside (static part of the mesh) was lagging (in time) slightly compared to the inside.
Anyone else notice this? |
Hi James.
I did have a similar problem at times; however, I did not investigate on the cause. Best regards, -Louis |
Antoine Devesa
Rep Power: 16 ![]() |
i guess this could be related to this one: http://www.cfd-online.com/Forums/ope...-postcalc.html
i hope this helps! |
vorticity calculation at symmetryplane | benconnell | OpenFOAM | 0 | April 14, 2009 18:45 |
Vorticity Iso-Surface | John | Main CFD Forum | 0 | April 4, 2009 23:10 |
GGI ERCOFTAC and general questions | david | OpenFOAM Running, Solving & CFD | 8 | August 25, 2008 09:22 |
Plotting Vorticity in CFX 11 | Venkatesh | CFX | 4 | August 6, 2008 06:26 |
vorticity depends on non-inertia frame of referenc | dingxi | Main CFD Forum | 3 | October 18, 2006 13:13 |
