April 28, 2006, 12:25 |
I am wondering if some is able
chris book
Rep Power: 17 |
I am wondering if some is able to "translate" me the code in a more mathematican way.
phi = fvc::interpolate(rho) *((fvc::interpolate(U) & mesh.Sf()) - fvc::meshPhi(rho, U)); > what is phi in this context? I do not understand how it is computed! for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::ddt(psi, p) + fvc::div(phi) - fvm::laplacian(rho*rUA, p) ); >How to determine this equation? I think this is PISO related stuff. pEqn.solve(); |
April 29, 2006, 09:26 |
Hi Chris,
in foam usually a
Markus Hartinger
Rep Power: 17 |
Hi Chris,
in foam usually all variables are stored at the cell centre. But for calculating the divergence of a field the face values are needed. So fvc::interpolate returns a field containing the face values interpolated from the cell-centre values. The interpolation scheme is defined in system/fvScheme by the entry interpolationScheme, usually linear. phi is in your example the mass-flux across the faces corrected for mesh-motion by fvc::meshPhi. the pEqn is part of PISO, probably you look in one of the foam thesis' for it's derivation or ferziger and peric regards Markus |
Param. & calculus in Fluent's Journal: Possible ? | Kiril | FLUENT | 0 | August 24, 2006 09:12 |
Syntax | r2d2 | OpenFOAM | 1 | December 13, 2005 13:19 |
Syntax What does mean | evgenii | OpenFOAM Pre-Processing | 2 | November 23, 2005 08:42 |
Syntax changes between versions 1.0.x and 1.1 | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | March 11, 2005 11:48 |
mesh and calculus servicies | ro-design team | Main CFD Forum | 0 | March 7, 2005 05:14 |
