Cartesian grid specific solverIterationpresure solver |
May 26, 2006, 07:04 |
I would like to know
anne dejoan
Rep Power: 17 |
I would like to know if there is any flag option in OpenFoam that could specify that the solver has to be applied to a cartesian grid. I asked this because (I think ?) it could avoid some CPU time when running on a cartesian grid (it would avoid all the surfave normal vectors computations and so on). Another question relates to the number of iterations required to solve the pressure. In a developped channel flow, when using the IGCCg solver it requires about 30 iterations for each pressure resolution and when using AMG it requires about 10-15. Is there aby way to optimize the iteration number ? Finally, I would like to know if OpenFoam makes use of Rhie-Chow interpolation. Thank You for your help, Anne |
May 26, 2006, 07:21 |
Cartesian Meshes
You are ri
Hrvoje Jasak
Rep Power: 33 |
Cartesian Meshes
You are right, on Cartesian meshes you could use special tricks to make the discretisation run faster by using the properties of the mesh. In order to do that, some methods (e.g. gradient) would have to be written again specifically for Cartesian meshes. This also leads to the issues with signalling (you would need 2 mesh classes) etc. and Cartesian meshes are not too useful. On balance, I would say this is not worth it - unless you wish to do things that are only possible on a Cartesian mesh (e.g. sixth order gradients). For this reason, OpenFOAM treats all meshes as unstructured polyhedral. The code has a natural slot for this kind of development: you could copy the finiteVolume library and re-implement the discretisation for the new mesh type. All other stuff, from pre-processing to matrices and fields can be re-used as appropriate. An example of something simular would be the finiteArea library, solving FVM on a curved moving 2-D surface mesh. Solver Sounds like for your case ICCG works much better - just pick that. This is why we've got several solvers in the first place :-) Rhie-Chow Interpolation Yes, of course, but not "by the book". Have a look at my Thesis or try to catch Rasmus Hemph - he has recently written a note about this. Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
May 26, 2006, 10:59 |
Dear Hrv,
Thank you for you
anne dejoan
Rep Power: 17 |
Dear Hrv,
Thank you for your fast answer. In our project we would like to perform LES for the study of contaminant dispersion in a urban context. For this we are thinking in using OpenFoam because it is an open source code. I have just started with DNS and LES of fully channel flow for a first go (I don't know anything about c++). The second step I think about is to perform a surface mounted cube in a channel. As it is still cartesian I was wondering about the possibility of switch off the unstructuired-related part to gain in CPU. But in viw of my poor knowledge in c++ I am not sure I will re-write the discrete operators. However, could you let me know where I can access your thesis ? It would be very helpfull for me to have it. I have two more quetions .... The first one is on turbulent inlet conditions issued from a precursor channel flow computation that I had posted. I still not have any answer, I know that you must be very busy but some indications on how to do it it would be great. The second is: is there any good tutorial to start with tracking particules and scalar passive transport? Thanks again, Anne |
cartesian vs cylindrical solver | giles | Main CFD Forum | 0 | August 26, 2008 20:00 |
Cartesian grid generation | bobbyzhu | Main CFD Forum | 0 | January 10, 2008 23:33 |
Cartesian Grid Generation | FASA | Main CFD Forum | 1 | June 19, 2006 06:13 |
Cartesian grid | apple | Main CFD Forum | 0 | April 9, 2006 10:09 |
Cartesian Grid | Harish | FLUENT | 0 | January 3, 2006 01:09 |
