May 18, 2006, 08:25 |
I am trying to program a
I am trying to program a radiation model using the Gibb's method (spherical harmonics) I used the "reactingFoam" solver, where I had a file IEqn.H with the following radiation equation : { fvScalarMatrix IEqn ( fvm::laplacian(I) - (I/(4*boltzmannCoeff) + pow(T,4))*(12*pow(knu,2 *boltzmannCoeff) == m ); IEqn.relax(); IEqn.solve(); thermo->correct(); } where I is the radiativ intensity I wanted to get from this equation After the compilation, when I execute reactingFoam, I get this message : --> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a calculatedFvPatchField. You are probably trying to solve for a field with a calculated or default boundary conditions. From function calculatedFvPatchField<type>::gradientInternalCoef fs() const in file fields/fvPatchFields/basicFvPatchFields/calculated/calculatedFvPatchField.H at line 174. In order to solve the I equation, I need of course some boundary conditions. I though the file I in the "0" directory of the case with the initial and boundary conditions was enough but it is apparently not the case. I try to see in the code an equation file like UEqn.H or hEqn.H but I did not see how the boundary equations are coded Could somebody give me some advices please ? Thank you in advance Julienh |
May 18, 2006, 09:26 |
Looks like one of the b.c.-s t
Hrvoje Jasak
Rep Power: 33 |
Looks like one of the b.c.-s that you specify in 0/I is not correct or that the field I has been created by calculation rather then read in. Have a look at the place where I is created and pay attention to the MUST_READ and only a mesh argument after the IOobject. For example:
volScalarField I ( IOobject ( "I", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Yours should look exactly the same. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
May 18, 2006, 11:13 |
Thank you for this quick
Thank you for this quick answer. I have exactly the same thing for I in the creatField file. I tried to change the boundary conditions but nothing work, I still have the same error about boundary conditions Best regards julienh |
May 18, 2006, 17:55 |
Hi Julien,
it can be a troubl
Tommaso Lucchini
Rep Power: 17 |
Hi Julien,
it can be a trouble of field definition (or in the createFields or the 0 directory), or a trouble when you try to solve the equation. Could you paste here how is defined I in the 0 directory? And how did you define it in the createFields? What is m? thanks. bye Tommaso |
May 19, 2006, 08:24 |
I found the mistake, I h
I found the mistake, I had a problem in the calculation of the emissivity, my code works quite well now and calculates the radiativ energy field. I will now try to couple this equation with the basic thermal equation because the convective part of the energy flow emitted by a flame has a direct influence on the radiativ part. But I have difficulties to find where the thermal equation is coded. Does somebody know ? Best regards julienh |
May 23, 2006, 05:28 |
Usually hEqn.H
Mattijs Janssens
Rep Power: 26 |
Usually hEqn.H
June 22, 2006, 07:51 |
As you have it coded, I believ
Michael Prinkey
Rep Power: 25 |
As you have it coded, I believe the (I/(4*boltzmannCoeff)) term is being treated as an explicit source term and ending up on the RHS. I think what you want to do is use fvm::Sp() to linearize that term and place it on the center coefficient instead. That should improve solution stability.
June 23, 2006, 04:57 |
Thank you for this
Thank you for this quick answer. I tried to do it with fvm::Sp() but it did not work. But I found one of my mistakes. The maxDeltaT was to large to satisfy the convergence criteria. Now it works but my model uses a fixed value of the optical thickness L and now I want my model to calculate L for each cell with the formula L = (2/3)*(volume of the cell)^(1/3) I coded : volScalarField L = (2/3)*pow (mesh.V(), (1/3)) but it did not work. Could somebody help me please ? Thank you in advance Best regards Julienh |
June 23, 2006, 05:09 |
Try
volScalarField L = (2.
#9 |
Eugene de Villiers
Rep Power: 21 |
Try
volScalarField L = (2.0/3.0)*Foam::pow(mesh.V(), (1.0/3.0)); If you do this a = (1/3) a = 0 Because you are doing integer division. |
June 23, 2006, 09:46 |
Thank you very much ! It works
#10 |
Thank you very much ! It works like this.
So my very simplified radiation model enables me to calculate the radiation flux I inside my combustion chamber. But to do it, I put boundary conditions for I in the 0 file like fixedValue or zeroGradient. However, the goal of my work is to calculate the field I on the wall of a furnace. The idea is to modify the wallHeatFlux file to add the radiatif flux to the convectif flux. But to do that, instead a BC like zeroGradient for I, I need to put a BC (I0) which is the solution of a new equation : (emissivityWall/4)*I0 - boltzmannCoeff*emissivityWall*Twall^4=(1/(3*a))*grad(I(0)) Am I obliged to create a new BC class to do that or is there a other way to do it ? Can somebody give me some advice please ? Thank you in advance Best regards JulienH |
June 27, 2006, 04:36 |
So, I can calculate th
#11 |
So, I can calculate the radiation flux within the furnace if I put existing boundary conditions like zeroGradient. But I need to put a calculated value for the boundary condition Iwall of field I. The code calculates Iwall but now I want to put Iwall as a boundary condition for I. So, I think I must code a new BC class. This class must just enable me to fill the /0 field for I like this : internalField uniform 25000; boundayField { walls { type boundaryConditionsforI; value Iwall; } } It is perhaps easy to do that butI am not a very good programmer. Could somebody give me some advise to program my own bounday conditions class please ? Thank you in advance Julien Heintz |
June 28, 2006, 11:16 |
Finally, I think I do
#12 |
Finally, I think I do not need to do my own boundary condition class for the field I so I tried to do it differently : here the code I had to my radiation solver in order to calculate the boundary field Iwall : Info<< "\nCreate new boundary condition\n" << endl; label inletPatchID = mesh.boundaryMesh().findPatchID("walls"); fvPatchScalarField& Iwall = I.boundaryField()[inletPatchID]; forAll(Iwall, faceI) { surfaceScalarField Iwall((0.6/epsilonWall)*fvc::snGrad(I) + 4*5.67e-8*pow(Tparoi,4)); I.boundaryField()[faceI] = Iwall; } I.write(); Info<< "\n ExecutionTime = " << runTime.elapsedCpuTime() << " s\n" << endl; } but it doesn't work. The field I is calculated but the boundary values of I remain constant, equal to the value I put in the 0/I file. What am I doing wrong ? Thank you in advance julienh |
Radiation P1 Model with Spectral Model: Multigray | A. Thellmann | CFX | 0 | October 25, 2008 13:44 |
Radiation Model - Spectral Model | Ray | CFX | 3 | April 10, 2006 10:33 |
Help: Radiation model | MANOJKUMAR | FLUENT | 4 | November 24, 2005 03:45 |
How to use radiation model with porous model? | jacky | CFX | 0 | December 17, 2002 23:51 |
DO model for RADIATION | Davide | FLUENT | 0 | October 21, 2001 04:13 |
