1. Is it possible to use Open Foam to calculate the drag of a given simple 3D object like a faired bike in this image
http://www.adventuresofgreg.com/HPVlog/photos/CFD1.JPG (the image was assumably produced with Solidworks) ? I intend to optimize the fairing to have as small drag as possible when a person is lying horizontally inside it. Some kind of 'virtual wind tunnel' would be ideal. Open foam is not available for windows 2000 (?). Could you recommend a solution for Windows? |
Mattijs Janssens
Rep Power: 26 ![]() |
Certainly. There is a steady state incompressible solver simpleFoam which will do this.
You will have to do the mesh generation and optimisation yourself. See http://www.cfd-online.com/cgi-bin/Op...=7303#POST7303 for a windows port. |
Drag calculation | Martins da Silva | FLUENT | 0 | November 24, 2006 13:18 |
calculation of drag | CFD | FLUENT | 11 | March 13, 2006 02:09 |
UDF for drag calculation | Luca | FLUENT | 0 | January 26, 2005 03:54 |
can phoenics simulate lake flow under wind drag | wady | Phoenics | 3 | August 17, 2004 06:37 |
calculation of drag coefficients | Longbin Tao | Main CFD Forum | 1 | May 5, 2000 12:08 |
