Linking libraries with wmake
Old   November 10, 2006, 09:30
Default I am currently a bit puzzled b
Rasmus Hemph
hemph is on a distinguished road
I am currently a bit puzzled by the compilation with wmake. In Make/options I have
EXE_LIBS = \
-L$(FOAM_LIBBIN) -lEulerianInterfacialModels \
-L$(FOAM_LIBBIN) -lphaseModel
Compilation runs fine, but at the linking stage, wmake picks up equally named libraries, not from $(FOAM_LIBBIN), but from $(FOAM_USER_LIBBIN). How can I get wmake to use the correct libraries?
hemph is offline   Reply With Quote
Old   November 10, 2006, 10:22
Default You can: 1. Either use the fu
Eugene de Villiers
eugene is on a distinguished road
You can:
1. Either use the full pathname for the libraries instead of the -l prefix
2. Delete the libraries in $FOAM_USER_LIBBIN
3. Rename the libraries in $FOAM_USER_LIBBIN
eugene is offline   Reply With Quote
Old   November 10, 2006, 10:40
Default Thanks for your reply Eugene,
Rasmus Hemph
Thanks for your reply Eugene, I resorted to number 3. However, I thought that the -L flag was there to tell gcc that is should use the supplied directory for the library in question. I am curious: why is it picking up libs from $(FOAM_USER_LIBBIN) ?
Old   November 10, 2006, 10:53
Default Heh, I dont know how or why it
Eugene de Villiers
Heh, I dont know how or why it works.
All I know is that there is a hierarchy defined somewhere and FOAM_USER_LIBBIN is higher up the pecking order than FOAM_LIBBIN.
Old   November 10, 2006, 13:16
Default Could it be ld using LD_LIBRAR
Mattijs Janssens
mattijs is on a distinguished road
Could it be ld using LD_LIBRARY_PATH?
From 'man ld':
The linker uses the following search paths to locate required shared libraries.
5. For a native linker, the contents of the environment variable
"LD_LIBRARY_PATH".
mattijs is offline   Reply With Quote
Old   November 13, 2006, 05:12
Default You are right! I did a bit of
Rasmus Hemph
You are right! I did a bit of Googling and found out what is going on. At compilation gcc uses the directories I supply with the -L flag. At the linking stage however, the linker looks to $LD_LIBRARY_PATH to see where the library I gave with the -l flag is located. Since $(FOAM_USER_LIBBIN) is ahead of $(FOAM_LIBBIN) in this path, my final application is linked to the "wrong" libraries in this case.
Solution?
One can supply commands to the linker by the -Wl-flag. By adding
-Wl, -rpath $(FOAM_LIBBIN) to the end of Make/options, the linker places this directory first in the search path, and the "right" libraries are linked to my application.
[Other] Using native MPI libraries arkangel OpenFOAM Installation 21 December 16, 2016 00:23
Problems linking my libraries with libfoamUser jblucca OpenFOAM Running, Solving & CFD 5 October 22, 2008 17:53
CGNS libraries, compiling and linking... Ironman80 Main CFD Forum 2 February 14, 2006 23:36
AMG libraries CMB Siemens 2 January 23, 2004 02:54
help on POOMA/PVM etc. libraries mayank Main CFD Forum 0 November 15, 2002 00:04
