Magnitude of the strain tensor
Old   June 15, 2007, 10:37
Default Hi FOAMers, I would like to
Max
didomenico is on a distinguished road
Hi FOAMers,
I would like to have your opinion about the following problem:
- the strain tensor is defined as
S = 2 * symm(grad(U)) = grad(U) + grad(U)^T (1)
- and, according to the linear algebra, its magnitude is
|S| = sqrt(.5 * (S_ij * S_ij)) (2)
- now, if I let OpenFOAM to write out both the U gradients and S
S = mag(2*symm(fvc:grad(U))) (3)
I see that values coming from (3) and (2) (calculated manually) are different.
I had a look to the vectorSpace class and what I can understand (with my little C++ knowledge), is that the magnitude of a tensor S is given by
|S| = sqrt(Sij * Sij) (4)
which differs from Eq. (2). Additionally, a manual check with the help of Eq.(4) does not return what is given by OF (Eq. (3)) and there is not any constant factor between their values...
What am I missing?
Thanks a lot,
Massimiliano
didomenico is offline   Reply With Quote
Old   August 7, 2011, 04:02
Claus Meister
idrama is on a distinguished road
Hello Foamer,
strain rate Tensor is defined by
S:=1/2 [ grad(U)+gard(U)^T]
Try it and give me respond if it's worked.
Cheers
idrama is offline   Reply With Quote
Vorticity magnitude CFD-junior Main CFD Forum 10 October 8, 2021 04:42
strain rate in UDF Paulina FLUENT 11 November 20, 2014 04:06
Rate of Strain Tensor from ANSYS FLOTRAN H Mayer Main CFD Forum 0 June 27, 2005 12:56
About the rotation and strain tensor maximus Main CFD Forum 2 March 6, 2005 05:18
second invariant of rate-of-strain tensor Chun Min Chew Main CFD Forum 3 December 10, 2003 12:34
