Generation of lists for Patch
Old   August 16, 2007, 19:40
Default hi, i worked some month ago
Stephan Gerber
stephan is on a distinguished road
hi,
i worked some month ago on similar things and as far as i remember there were two different index-systems :one local in the block and one for the whole mesh - maybe thats causing the problem?!(only in case you are using more than one block..)
i think i used a function called "whichPatch" or "whichFace" to convert the index...
hope that helps?!
regards
stephan
stephan is offline   Reply With Quote
Old   August 17, 2007, 06:08
Default I've noticed the different ind
David Mulholland
irishdave is on a distinguished road
I've noticed the different index-systems and I believe the way I have been doing it should take account for that? This is why my Owner and Neighbour lists are generated from the faceCells counting value. Then I use the faceCells[cell] value (which should be the value from the actual mesh) for use when getting the cell centre value for output.
I will have a look at those functions and see if it will help. Thanks for the input Stephen. I'm hoping to make something which will be made available to the community and be pretty useful for anyone doing LES simulations.
David
irishdave is offline   Reply With Quote
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 10:42
BC evaluation by means of external lists allocated in the solver shrina OpenFOAM Running, Solving & CFD 2 January 18, 2007 12:29
patch. Ehsan Alborzi FLUENT 1 February 12, 2004 07:31
patch lu FLUENT 2 September 4, 2003 04:48
Patch Eric FLUENT 5 December 1, 2000 11:14
