What is the meaning of
Old   February 1, 2008, 13:00
Default Hi all, I know that maybe
Francesco Boschetto
francesco_b is on a distinguished road
Hi all,
I know that maybe it could be a silly question, but I'm a beginner and somewhere I need to start
in the file inletOutletFvPatchField.C there is this expressions:
template<class>
inletOutletFvPatchField<type>::inletOutletFvPatchF ield
const fvPatch& p,
const DimensionedField<type,>& iF
mixedFvPatchField<type>(p, iF),
phiName_("phi")
this->refValue() = pTraits<type>::zero;
this->refGrad() = pTraits<type>::zero;
this->valueFraction() = 0.0;
What is the meaning of the ":"? Is it only a way to say that the line goes on through next line?
Thanks in advance
Francesco
francesco_b is offline   Reply With Quote
Old   February 1, 2008, 16:37
Default Francesco, This confused me
C.E.M.
evan is on a distinguished road
Francesco,
This confused me too. Check here:
http://www.cs.huji.ac.il/labs/parall...e/tic0143.html
with operator overload I think you can also use it with an access specifier.
Evan
evan is offline   Reply With Quote
Old   February 1, 2008, 18:05
Default It's an initialization list fo
Sandeep Menon
deepsterblue will become famous soon enough
It's an initialization list for member data. For classes that don't provide a default null-constructor, this is the only way to go, since the object (in this case: mixedFvPatchField<type>(p, iF),etc ) needs some initial parameters for the constructor.
Other situations in which this happens:
When you have references as member data. Something like - label& myData_;
When the object is created, myData_ MUST have a reference to something, otherwise, it's invalid.
Hope this helps
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   February 4, 2008, 05:54
Default Hi Evan and Sandeep, Thanks
Francesco Boschetto
Thanks for your help, now it is clear
Regards,
Francesco
What is the meaning.. ??? lopez FLUENT 6 November 2, 2016 04:48
want to know meaning Sangamesh Siemens 0 May 15, 2007 06:15
what is the meaning of this dpshaka Main CFD Forum 0 December 15, 2005 22:24
what's the meaning arwang FLUENT 4 May 3, 2005 08:34
meaning id Main CFD Forum 0 September 18, 2003 05:01
