October 19, 2012, 20:01 |
#121 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 20, 2012, 09:16 |
#122 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Although... I've used Thunderbird with success to monitor RSS feeds on pages that require log-in. But I haven't found any page I could test this with mediawiki pages...
February 20, 2013, 09:06 |
#123 |
Bruno Santos
Rep Power: 128 |
FYI: openfoamwiki.net seems to be down at the moment, 13h00 GMT.
February 20, 2013, 10:17 |
#124 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Thanks for reporting. For some reason the machine ran out of memory. As the uptime is already ruined I'll update the OS (so expect another downtime in the next hour)
February 20, 2013, 18:06 |
#125 |
Bruno Santos
Rep Power: 128 |
If the server doesn't have swap turned on, then perhaps the faulty application is "console-kit-daemon". It has been plaguing one of our servers for quite some time now... and the simplest solution so far has been to reboot every couple of months .
February 21, 2013, 11:56 |
#126 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm afraid no. There is not even a program of that name on my machine (sounds like some desktop-stuff and I don't have that on that server)
March 6, 2013, 14:13 |
#127 |
Just to let you know:
It seems the server is down again at the moment. A ping -c 3 gives a complete package loss... Shall we see that as a positive notice that maybe the message will be removed concerning the non-reachability of the sourceforge-repository? ;-) |
March 6, 2013, 14:32 |
#128 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm afraid no. This is just a sign that the server needs to be moved to a bigger machine
March 9, 2013, 19:05 |
#129 | |
Bruno Santos
Rep Power: 128 |
And the wiki is down again... just when I was taking care of uploading the new templates for OF 2.2* images
edit: nevermind, it's up again... edit 2: er, then again maybe not... but I got a convenient message indicating the server is having issues Quote:
Last edited by wyldckat; March 9, 2013 at 19:13. Reason: see "edit:", "edit2:" and "edit3:" |
March 10, 2013, 07:13 |
#130 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Bruno,
Thanks for adding the version template - perfect timing, as I have just been adding it to the waves2Foam-wiki Enjoy the rest of your Sunday, Niels |
March 10, 2013, 07:17 |
#131 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
March 27, 2013, 02:46 |
#132 |
Rep Power: 37 |
Good morning,
I have a problem connecting to the Wiki this morning. Happy Easter / Niels |
March 27, 2013, 05:32 |
#133 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Thanks for the ping. Rebooted it. Seriously considering a new physical machine
March 27, 2013, 05:33 |
#134 |
Rep Power: 37 |
And again it works like a charm Thanks.
March 29, 2013, 20:09 |
#135 | |
Bruno Santos
Rep Power: 128 |
If this is the case, then no matter how much RAM the machine has, it will likely run out of memory no matter what...
April 2, 2013, 08:09 |
#136 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
April 3, 2013, 19:07 |
#137 |
Bruno Santos
Rep Power: 128 |
And the wiki is out cold again
April 3, 2013, 19:49 |
#138 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
That's strange. Because I see it without problems (from home). And when I check the uptime it doesn't seem like it rebooted
April 3, 2013, 19:55 |
#139 | ||
Bruno Santos
Rep Power: 128 |
April 5, 2013, 15:36 |
#140 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Strange. Because I never see that (which doesn't mean that I don't believe in the existence of such a page .... but let's not get philosophical here). Next time you see that page could you send me a mail (or a message here) with the time you saw it and I'll check the logs
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam/60855-wiki.html
Posted By | For | Type | Date | |
OpenFOAMWiki | This thread | Refback | July 16, 2012 05:06 |
Wiki | iyer_arvind | OpenFOAM Running, Solving & CFD | 1 | July 26, 2007 03:12 |
Wiki | Dan | Main CFD Forum | 1 | February 4, 2007 19:14 |
CFD-Wiki - We Need Your Help! | Jonas Larsson | Main CFD Forum | 5 | May 12, 2006 09:25 |
CFD Wiki - We Need More Help! | Jonas Larsson | Main CFD Forum | 0 | September 26, 2005 09:11 |
CFD Wiki - We Need More Help | Jonas Larsson | Main CFD Forum | 13 | September 13, 2005 18:36 |
