April 21, 2008, 14:12 |
OpenFOAM has this cool feature
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
OpenFOAM has this cool feature named functionObjects of which the only incarnation I've seen so far is the probesFunctionObject. functionObject enables the user to "add" code to the solver at runtime (without recompiling it) that is executed at every time-step.
I have published a collection of such function objects on http://openfoamwiki.net/index.php/Co...unctionObjects that do simple evaluations that are sometimes useful like averages, integrals, forces, mass-flows on patches and/or volumes. The actual library can be downloaded via subversion: svn checkout https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Breede r/libraries/simpleFunctionObjects/ If anyone has * ideas for extensions (a liftDrag-FunctionObject comes to mind) * bugfixes/stylistic suggestions (and there are bound to be some) she/he is welcome to contribute these via the technical wonder that is called subversion (you'll just need write access to the svn) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
April 22, 2008, 00:50 |
This looks interesting.
Tha
Alberto Passalacqua
Rep Power: 36 |
Thanks!
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 22, 2008, 05:57 |
Maybe this is also o
Hannes Kröger
Rep Power: 18 |
Maybe this is also of interest for someone: I have wrapped the code of the sampleSurface tool into a function object. Together with an additional writer for the PlotMTV-Format (PlotMTV is a very lightweight contour plot program), this makes it possible to get insight into the fields without always copying files and loading the whole case into Paraview. I find this especially useful for large, parallelized cases (no reconstruction is needed, this is done for the sample planes on the fly). The code is in our SVN-repository: https://janus.fms.uni-rostock.de/svn/repository/OpenFOAM/trunk/LTTRostockExtensi ons Username is "gast" with blank password. Best regards, Hannes
silentdynamics GmbH - http://silentdynamics.de open source CAE software solutions & support |
April 22, 2008, 06:25 |
Hannes,
Does plotmtv requir
Mark Olesen
Rep Power: 40 |
Hannes,
Does plotmtv require regular distances between data points, or does it perform its own kriging? /mark |
April 22, 2008, 07:59 |
Hi Mark,
PlotMTV can interp
Hannes Kröger
Rep Power: 18 |
Hi Mark,
PlotMTV can interpolate in unstructured triangulated surfaces. The data is written out that way. But it is limited to planar surfaces and the writer currently only supports "interpolatedPlane"s Hannes
April 22, 2008, 19:23 |
Hi Hannes!
That is really a
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Hannes!
That is really a nice one. But is my impression correct that currently each time it writes out the sampled surfaces for one timestep all the previous outputs get erased? I had to comment out the lines in the sampleSurfaceProbesFunctionObject::execute()-method that erased sampleSurfaces-directory in order to get time-series Bernhard
April 23, 2008, 07:43 |
Hi Bernhard,
yes, you are r
Hannes Kröger
Rep Power: 18 |
Hi Bernhard,
yes, you are right. Initially, I also used it without deleting the directories. But since I usually write out samples pretty often and do not want to end up with lots of data garbage, I put it in again. I have inserted a switch for that right now ("deleteOutputDirectory") , which defaults to "yes" Hannes
April 23, 2008, 08:29 |
Hi Hannes!
Cool. I know thi
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Hannes!
Cool. I know this is becoming annoying BUT: 1. I think the setting outputInterval should be called outputInterleave because setting it to 1 outputs every second timeStep. Setting it to 0 switches the output of (this is obviously intended). So it is not possible to output every timestep. Initializing the timeSteps_ variable to 1 instead of 0 (I think in 3 places in the code) would give the behaviour I would expect 2. If deleteOutputDirectory==No removing the directory in the start-method would give a behaviour that is semantically similar to what the original probes does 3. I know this is asking much: would it be possible to factor this thing out into a separate library? Right now I've got to edit Make/options and Make/files to get it to compile (the chemistry-stuff). And while you're at it: would you consider putting it on openfoam-extend (just this sampleSurface-stuff)? Bernhard
April 24, 2008, 04:08 |
Hi Bernhard,
Please feel fr
#9 |
Hannes Kröger
Rep Power: 18 |
Hi Bernhard,
Please feel free to improve the code as you want. I would add that stuff e.g. to the "simpleFunctionObjects" library and remove it from our lib. But I guess I need write access to the sourceforge repository to do so (my sourceforge username is "hanneskroeger"). Hannes
April 24, 2008, 05:36 |
Hi Hannes!
Great. I added y
#10 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Hannes!
Great. I added you to the users with svn write access and prepared a directory "sampling". Just put your stuff there (in such a way that if someone else feels like adding a sample-functionObject, it can live in parallel to your stuff) and add yourself as a contributor to the README-file. Just one question? Did you have to do any changes to the original sampleSurface-stuff you're using? If not, it should be possible to modify the Make/files to sampleSurface=$(FOAM_UTILITIES)/postProcessing/miscellaneous/sampleSurface $(sampleSurface)/surfaces/surface/surface.C ..... thus pulling in the original stuff (and not adding it to the repository) and only add the new stuff (the MTV-writer) from that hierarchy Bernhard
April 24, 2008, 07:21 |
Hi Bernhard,
I have done as
#11 |
Hannes Kröger
Rep Power: 18 |
Hi Bernhard,
I have done as you suggested and added all the sampleSurface-stuff to Make/files at their original location. Unfortunately, there might be problems due to the *.dep files in $(FOAM_UTILITIES)/postProcessing/miscellaneous/sampleSurface. After compilation of the sampleSurface utility, they contain relative paths. So you might consider doing a "wclean" in $(FOAM_UTILITIES)/postProcessing/miscellaneous/sampleSurface to delete all *.dep files first, before building the library. After building the library, the *.dep files contain absolute paths. Hannes
April 25, 2008, 11:01 |
Hi Hannes!
I noticed so, to
#12 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Hannes!
I noticed so, too. It's especially inconvenient for people who don't have write-rights on their OF-installation. I'll think of a fix Bernhard
May 26, 2008, 17:43 |
Hi Hannes!
I "fixed" the pr
#13 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Hannes!
I "fixed" the problem with the external dependencies some time ago (maybe you noticed in the SVN), but forgot to mention it here: the fix consists of a script that copies the external dependencies to the compilation directory (it is described in the README) Bernhard PS: the real reason why I'm writing here is that I added a new functionObject (panicDump) to the library and wanted to advertise it. It checks whether the values in a field are inside certain bounds and if they are outside writes all fields to disk and exits. The purpose of this FO is to gracefully stop simulations that are obviously going to explode while the fields still might be useful for post-mortem analysis (not full of NaNs or 1e43)
May 27, 2008, 03:54 |
When I try to compile the simp
#14 |
Juho Peltola
Rep Power: 17 |
When I try to compile the simpleFunctionObjects at /utilities/simpleFunctionObjects with
wmake libso I get the error message make: *** No rule to make target `externalStuff/surfaces/surface/surface.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop. I'm using 1.4.1, GCC 4.2.1 and Binutils 2.18 Could anyone give me guidance on how to get it to compile? |
May 27, 2008, 04:50 |
Hi Juho!
Please do the foll
#15 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Juho!
Please do the following (just to make sure we're starting off the same version). In the directory - do a "svn update" - remove externalStuff - do "wclean" and "rmdepall" Then set up the externalStuff as described in the README and retry Bernhard
May 27, 2008, 05:15 |
Oh, there's a README...
Com
#16 |
Juho Peltola
Rep Power: 17 |
Compiled without complaints! Thank you for the help and sorry for the stupid question! |
May 29, 2008, 03:22 |
Could you point me in a direct
#17 |
Juho Peltola
Rep Power: 17 |
Could you point me in a direction for modifying the output of patchFieldFlow in a way that it could be used as an input for timeVaryingUniformFixedValue boundary condition?
Only thing the output would need is brackets around the values. ie. ( 1 0 2 1 3 1 4 10 5 1 ) |
May 29, 2008, 04:07 |
The first bracket was easy, ju
#18 |
Juho Peltola
Rep Power: 17 |
The first bracket was easy, just added it to timelineFunctionObject.C
April 2, 2009, 03:00 |
compilation error
#19 |
Prapanch Nair
Rep Power: 17 |
Hi Bernhard,
Thank you for this cool tool. I have OF 1.5. When I tried to compile using wmake libso, I got a compilation error. Let me paste the last few lines of the compilation output: SOURCE=trackDictionary/trackDictionaryFunctionObject.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/sampling/lnInclude -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/triSurface/lnInclude -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rwdi-india/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/trackDictionaryFunctionObject.o trackDictionary/trackDictionaryFunctionObject.C: In member function ‘void Foam::trackDictionaryFunctionObject::echoSwitchesV alues()’: trackDictionary/trackDictionaryFunctionObject.C:201: error: ‘tolerances’ is not a member of ‘Foam::debug’ make: *** [Make/linuxGccDPOpt/trackDictionaryFunctionObject.o] Error 1 And then compilation exits. I am not able to use the functions after this. Is that a bug or am I doing something wrong here? Thank you Prapanj. |
April 2, 2009, 09:29 |
#20 | |
Martin Beaudoin
Rep Power: 22 |
My mistake,
I published a new functionObject this week on openfoam-extend, and this code was developed for 1.5-dev. The "tolerances" switches are available only under the dev version of OpenFOAM. I will fix this shortly. Martin Quote:
Variable deltaT and functionObjects | henrik | OpenFOAM Bugs | 8 | July 22, 2009 05:11 |
OF15 functionObjects do not read LESProperties for incompressible flows | aunola | OpenFOAM Bugs | 1 | September 28, 2008 18:18 |
Collection Codes OpenFoam | larry | OpenFOAM Running, Solving & CFD | 0 | July 3, 2006 18:11 |
Collection efficiency | Jen | FLUENT | 0 | November 16, 2005 11:16 |
Data output collection | simon | Main CFD Forum | 0 | September 29, 2003 10:03 |
