Foam 13 How can one run solver in debugger
Old   April 7, 2006, 19:25
Default I would like to ask how can i
atzaru
I would like to ask how can i debug simpleFoam solver in ddd. I understand that i need to recompile the code. What i need to changde and where?
Thank u very much
Atzaru
Old   April 8, 2006, 08:04
Default Look in .OpenFOAM-1.3/bashrc,
Max
didomenico is on a distinguished road
Look in .OpenFOAM-1.3/bashrc, you have to comment out the following option:
export WM_COMPILE_OPTION=Debug
and re-source the file. After that, go to OpenFOAM-1.3 and run
./Allwmake
that's all...
Remember I will have both the optimized and debug versions installed and you can switch between them with that flag.
didomenico is offline   Reply With Quote
Old   April 8, 2006, 09:21
Default It might be easier to only com
Mattijs Janssens
mattijs is on a distinguished road
It might be easier to only compile (a copy of) the conflicting command (unless your bug is in one of the libraries). Search on this forum for FULLDEBUG.
mattijs is offline   Reply With Quote
Old   April 11, 2006, 04:07
Default Hi thanks a lot for the tip
atzaru
Hi
thanks a lot for the tips
I compiled the code with
export WM_COMPILE_OPTION=Debug activated and i obtain the following type of errors:
bin/linuxGcc4DPProf/setFields
/usr/bin/ld: cannot find -lOpenFOAM
collect2: ld returned 1 exit status
make: *** [/home/gda/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPProf/setFields] Error 1
+ wmake mapFields
make: *** [/home/gda/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPProf/foamInfoExec] Error 1
gda@tzapuu:~/OpenFOAM/OpenFOAM- 1.3$
Does anybody know how i can fix it?
thanks
Old   April 11, 2006, 06:22
Default You don't have the debug versi
Mattijs Janssens
You don't have the debug version of the library compiled. If you follow Massimilianos steps so recompile everything you will end up with a whole set of debug libraries.
E.g. where my libOpenFOAM is now in
.../linuxGcc4DPOpt/libOpenFOAM.so
it will then be in something like
.../linuxGcc4DPDEBUG/libOpenFOAM.so
With you it actually looks like your binaries end up in 'linuxGcc4DPProf/' but anyway you don't seem to have libraries in the corresponding library directories ($FOAM_LIBBIN).
(you could always try the local compilation option in my post above)
Old   October 17, 2007, 07:12
Default Hej, I am trying to debu
mss
Hej,
I am trying to debug my own solver in OpenFoam. For this I added a line in
the Make/options:
EXE_INC =\
-DFULLDEBUG -g O0
and I used the comand line : gdb <name_solver> <case_name>
But It seems to be be something wrong in this line.
Could someone give some instructions on how to use interactive debugger in
openFoam step by step for person who is new in this area?
Thank you in advance,
Rita
Old   June 10, 2008, 04:13
Default Hi I am a beginer with OpenFO
marevaz
marevaz is on a distinguished road
Hi
I am a beginer with OpenFOAM.
Can i trace a solver line by line in debug mode?
if yes, how can i do that?
Thank You.
marevaz is offline   Reply With Quote
Old   July 6, 2009, 12:45
karlvirgil's Avatar
karlvirgil is on a distinguished road
Originally Posted by marevaz View Post
Hi
Thank You.
Yes you can. All you need to do is recompile OpenFOAM with the debug option turned on (see etc/bashrc file in OpenFOAM installation). Then, launch application in gdb and step through the code
karlvirgil is offline   Reply With Quote
Sonic foam solver for a subsonic problem chable OpenFOAM Running, Solving & CFD 2 August 15, 2016 11:11
Simple foam solver mardinoglu OpenFOAM Running, Solving & CFD 1 October 17, 2014 05:56
FEM solver in FOAM Hrvoje Jasak (Hjasak) OpenFOAM 2 March 31, 2013 13:52
debugger with STAR CD V4 Jaishree Siemens 1 December 2, 2007 15:40
First steps w moving mesh FOAM FATAL ERROR solver table is empty tehache OpenFOAM Running, Solving & CFD 2 May 14, 2007 05:59
