Directory constructions of complex cases
Old   August 25, 2008, 12:16
Default Hi, As far as I understand Op
Takuya OSHIMA
7islands is on a distinguished road
As far as I understand OpenFOAM case directories are organized as follows, but I have no idea where Lagrangians go into for several cases. Can you tell me about it for cases marked as "?" below?
For usual simple cases a case directory is organized as:
Mesh: case/time/polyMesh/meshFile
Field: case/time/field
Lagrangian field: case/time/lagrangian/cloudRegion/field
For parallel decomposed cases:
Mesh: case/processor/time/polyMesh/meshFile
Field: case/processor/time/field
Lagrangian field: case/processor/time/lagrangian/cloudRegion/field
For multi-region cases:
Mesh: case/time/region/polyMesh/meshFile
Field: case/time/region/field
Lagrangian field: ?
For parallel decomposed multi-region cases:
Mesh: case/processor/time/region/polyMesh/meshFile
Field: case/processor/time/region/field
Lagrangian field: ?
Thanks,
Takuya
7islands is offline   Reply With Quote
Old   August 26, 2008, 05:29
Default For multi-region cases: Me
Mattijs Janssens
mattijs is on a distinguished road
Lagrangian field: case/time/region/lagrangian/cloudName/field
and decomposed same but in case/processor*
(you can try with foamToVTK -region XXXX)
mattijs is offline   Reply With Quote
Old   August 26, 2008, 06:25
Default Thanks a lot, Mattijs! Taku
Takuya OSHIMA
Takuya
Nonexistent run directory martapajon OpenFOAM Running, Solving & CFD 1 August 6, 2007 14:54
[Netgen] Importing mesh for complex 2D cases edvardsenpriv OpenFOAM Meshing & Mesh Conversion 2 December 6, 2005 06:23
Change directory Nikhil FLUENT 1 October 11, 2005 07:51
Fluent Directory Johnnyb FLUENT 1 September 1, 2003 10:48
Check cases for turbulance heat transfer on a complex shape Mehdi Main CFD Forum 3 June 1, 2000 23:36
