January 23, 2015, 02:02 |
#41 |
s_shimz
Rep Power: 15 |
Thank you for sharing the reference!
March 22, 2015, 08:46 |
#42 | |
Marco
Rep Power: 12 |
would you repost/update your link? Thanks in advance! |
March 23, 2015, 04:43 |
#43 | |
Roman Thiele
Rep Power: 21 |
http://www.abcm.org.br/anais/cobem/2001/home.htm -> just go to Lectures link. the pdf can be found there
~roman |
June 23, 2015, 13:39 |
Paper kwSST OF
#44 |
Daniel Rodriguez Calvete
Rep Power: 14 |
I will be very greatful if someone can send me the paper mentioned before, in which komegaSST in openFoam is based: "Heat Transfer Predictions based on Two-Equation Turbulence Models with Advanced Wall Treatment" T.Esch and F.R. Menter - Turbulence, Heat and Mass Transfer 4. (Menter, F., Esch, T., "Elements of Industrial Heat Transfer Prediction", 16th Brazilian Congress of Mechanical Engineering (COBEM), Nov. 2001.) My email is: daniel.rcalvete@udc.es Thank you in advance. |
June 23, 2015, 13:54 |
#45 |
Rep Power: 14 |
I find it. Thanks Romant for the link, I did not read your post before to ask for it.
October 7, 2015, 14:16 |
#46 |
Angel Monsalve
Rep Power: 17 |
Thanks Romant, it will be very helpful
April 1, 2016, 12:00 |
Paper
#47 |
Humberto
The paper (Menter, F., Esch, T., "Elements of Industrial Heat Transfer Prediction", 16th Brazilian Congress of Mechanical Engineering (COBEM), Nov. 2001.) can be downloaded from the website:
http://www.abcm.org.br/anais/cobem/2001/home.htm |
April 12, 2016, 11:09 |
#48 |
Pete Bachant
Rep Power: 14 |
I went ahead and extracted the relevant paper from the proceedings: https://drive.google.com/file/d/0BwM...ew?usp=sharing
October 4, 2016, 06:12 |
Paper ?
#49 |
Vijaya Kumar. G
Rep Power: 10 |
Could someone provide me with the Paper ??
vjykmr44@gmail.com |
October 4, 2016, 07:23 |
#50 | |
Roman Thiele
Rep Power: 21 |
Please have a look at the thread above.
~roman |
October 11, 2018, 09:24 |
#51 |
Rep Power: 9 |
Hi everyone!
I know I am a couple years late, but if it is still of interest, the paper can be found here: http://abcm.org.br/anais/cobem/2001/pdf/Lectures.pdf Go to page 117 of the pdf or Ctrl+f: Menter (a couple times). Hope it helped someone. Regards, Okubo |
June 24, 2020, 19:56 |
#52 |
Hector
Rep Power: 16 |
Dear all:
I have the paper from abcm.org.br as pointed out before But the resolution of the images is very bad. Does anyone has a better resolution version? |
June 25, 2020, 22:54 |
Better resolution "ELEMENTS OF INDUSTRIAL HEAT TRANSFER PREDICTIONS" Menter 2001
#53 |
Hector
Rep Power: 16 |
DES ( SA+LES) vs DES ( kwSST+LES) for bluff body | Phil | Main CFD Forum | 0 | January 8, 2008 10:04 |
Validation of shear mixing layer using kwsst | Samuell | FLUENT | 0 | September 9, 2003 23:46 |
Validation of shear mixing layer using kwsst | Samuell | FLUENT | 0 | September 9, 2003 23:27 |
Does somebody has the eletronic copy of this paper | Puma_Lihh | Main CFD Forum | 3 | March 25, 2003 09:31 |
copy and paste.... | giosue | Siemens | 4 | March 3, 2003 11:42 |
