Open Foam for ship hydrodynamics
Like Tree1Likes
Old   February 10, 2012, 03:38
Default Hydrodynamics(under water vechile)
  #21
hhh
kunar
hhh is on a distinguished road
Dear foamers,
i am doing analysis under water vechile,i just design in catia,please give idea how i start with this one it has rectangular box six padles(left side 3 and right side 3) to flap in under water.please give me idea with basic how i start with preprocessing(mesh) and solver.please find my attached design.
Regards,
hhh
kumar
hhh is offline   Reply With Quote
Old   August 12, 2014, 08:37
Sachin
Sachin m is on a distinguished road
Originally Posted by lillberg View Post
I've been working with underwater and free surface hydrodynamics using FOAM and now OF since 1999 computing several benchmark cases including Wigley hulls, DTMB 5415, DARPA Suboffs etc using LES and VOF implementations. Most of the work is published or found in conference procedings. If you're interested please send me an email and I'll send copies of the papers.
Regards
/Eric
Hi Eric ,
Iam sending this email in regard to your post on 'CFD ONLINE' relating to benchmark cases of several hulls using LES and VOF. I am a Mtech student and my project is related to the hydrodynamics of vessel. I would like to know more about ship hydrodynamics in OPEN Foam and in particular the wigley hulls using VOF method. Please help me out by sending a copy of this particular case.
Sachin m is offline   Reply With Quote
Old   August 12, 2014, 10:48
Default convergence problems
  #23
David Fuentes
fondexx is on a distinguished road
hi partners
I'm trying to make a CFD analysis of the KCS hull using interFoam, butn I can't find the convergence and when I see the results on para Foam I can see some interference or something, can you help me?
File Type: jpg Screenshot from 2014-08-12 09:42:59.jpg (81.0 KB, 86 views)
File Type: jpg Screenshot from 2014-08-12 09:44:02.jpg (80.4 KB, 78 views)
File Type: jpg Screenshot from 2014-08-12 09:19:38.jpg (46.8 KB, 70 views)
fondexx is offline   Reply With Quote
Old   September 1, 2014, 01:40
Sachin
Hi all,
I have run a drag force analysis of accustom hull using LTSInterFoam.
But after 12000 runs the free surface is seen above the ship hull. What could be the possible reason. Could it be because the solution is not yet stable. Should I run this for more number of iterations?
One more thing, I need to find the drag force on the hull. The function to write the force that I have asks for only one density value. How can that function give me the drag when it is a multiphase problem. There should be two values of density changing with the value of alpha1. Can anybody help me with this?
Below I am attaching few results:
1) The meshed hull with value of alpha1 shown. Blue region is air; red region is water.
2) Free surface after 100 iterations
3) free surface after 12000 iterations.
Old   October 28, 2014, 02:33
Sachin
Has anyone tried the propeller tutorial in openFoam??
If yes let me know how to go about it.
My allrun file is not working. So iam trying to run it manually.
Can anyone help me out with the steps???
Thanks in advance.
Old   March 14, 2021, 17:43
Default interface capture
  #26
Deutschland
vava10 is on a distinguished road
Hey,
I working on ship simulation using OpenFOAM. This is my first project using openFoam.
I tried to capture the interface as follows as per one of the papers which I read
1.Creating a background mesh with blockMesh. blockMesh
2.Using snappyHexMesh to insert geometry, refine around geometry and other regions of interest by isotropic splitting of cells in all three dimensions. snappyHexMesh with castellatedMeshControls true and others false
3.Selecting the free surface region by using topoSet utility. topoSet
4.Refining mesh, based on the cells selected in topoSet, in vertical direction only using the refineMesh utility. refineMEsh
5.Snapping the mesh to the geometry surface and adding layers with snappyHexMesh. snappyHexMesh with castellatedMeshControls false and others true
But I get the following error while running this case in HPC
cell 3773907 of level 0 uses more than 8 points of equal or lower level
from the forum I got why the error comes (SnappyHexMesh problems)
My geometry is a kayak whose width is 0.41m and dept 0.29. I used a 0.55 refinement zone(depth) for the water surface capture because if I go below the valoe of 0.2 for the refinement zone the refinement zone is not visible beyond the refinement box for the ship
Is there any other options to capture the interface?
Can you please help me
Thanks in advance
vava10 is offline   Reply With Quote
Old   March 14, 2021, 17:48
  #27
Deutschland
Sorry. I accidentally posted here. This was supposed to be under another thread
But if anyone can help, I would appreciate it
Old   March 14, 2021, 17:54
  #28
Deutschland
Hey,
Thanks in advance
Ship hull hydrodynamics Costa Main CFD Forum 2 May 19, 2012 22:41
An Open Source mesh generator for Open Foam Ahmed Main CFD Forum 15 September 23, 2010 19:39
turbulence model for ship hydrodynamics ettax Siemens 0 January 20, 2009 06:02
