Description of reactingFoam solver
Old   May 15, 2006, 12:10
Default Dear all, I am trying to un
Daniele Panara
panara is on a distinguished road
Dear all,
I am trying to understand the PaSR model implemented in reactingFoam, anybody knows any reference paper?
Regards,
Daniele
panara is offline   Reply With Quote
Old   May 15, 2006, 12:46
Default Hi Daniele, I have some mate
Tommaso Lucchini
lucchini is on a distinguished road
Hi Daniele,
I have some material about the Partially Stirred Reactor Combustion Model. If you send me an e-mail, I can give you some references
Bye
Tommaso
lucchini is offline   Reply With Quote
Old   May 15, 2006, 12:56
Default Dear Tommaso Could you giv
cfdfans
Dear Tommaso
Could you give some references about
cfdfans@163.com
thank you very much!
qf
Old   June 1, 2007, 08:12
Default Hello Tommaso, I'm also int
Michele Vascellari
mighelone is on a distinguished road
Hello Tommaso,
I'm also interesting in Partially Stirred Reactor model and its cfd implementation.
Could you send me some references/informations about it?
Is this model the same defined as MIL (lagrangian intermittent model), proposed by Borghi?
Can it be used for nonpremixed combustion?
Thank you for your attention!!!
Michele
mighelone is offline   Reply With Quote
Old   June 1, 2007, 08:53
Default Hi Michele, the partially
Tommaso Lucchini
Hi Michele,
the partially stirred reactor is basically a modified version of the Eddy Dissipation Concept by Magnussen to account for turbulence/chemistry interaction. Please have a look to the following article:
"Flame lift-off in Diesel Engines" by Karlsson and Chomiak published in the proceedings of the combustion institute (I can send you a copy if you need).
The PaSR model is generally used for turbulent non-premixed combustion. However, there are different interpretation of the chemical time scale tc and they can play a strong influence on the results.
Can I have some references to the MIL model by borghi?
Thanks a lot, bye
Tommaso
Old   June 1, 2007, 09:38
Default Dear Tommaso, can you send me
Michele Vascellari
Dear Tommaso,
can you send me a copy of the Karlsson paper?
The reference for MIL model is:
Borghi R. Turbulent combustion modelling, Prog Energy Combustion Sci 1988; 14:245-92
I do not have this paper, but I've read something about it from the work of Veynante and Vervish (Progress in energy and combustion science 28 2002 193-266).
The MIL model is based on a calculation of the ignition time by means of a PaSR calculation, and the mean burning rate is obtained from the integration of a pdf function dependent by this time.
Thanks a lot,
Michele
Old   September 21, 2007, 11:40
Default Hi Tommaso, can you send me
Michele Vascellari
Hi Tommaso,
can you send me a copy of "Flame lift-off in Diesel Engines" by Karlsson and Chomiak.
My e-mail is vascellari@dimeca.unica.it
Thank you for your help
Michele
Old   October 19, 2007, 10:37
Default Hi Tomaso Do you know if I
Wladimyr Mattos da Costa Dourado
mattos is on a distinguished road
Send a message via Skype™ to mattos
Hi Tomaso
Do you know if I can use the XI-b partial premixed model to calculate non-premixed combustion flow. I'm reading the Henry Weller's report and is not clear for me if I can do it or not.
Tanks in advance!
Wladimyr
mattos is offline   Reply With Quote
Old   October 19, 2007, 11:54
Default Hi Wladimir, the Weller com
Tommaso Lucchini
Hi Wladimir,
the Weller combustion model is for PREMIXED COMBUSTION, since it divides each computational cell in two zones:
b = 0: fully burnt (burnt gases).
b = 1: fully unburnt (air+fuel).
The flame propagation speed is proportional to the flame wrinkling (Xi) and to the laminar flame speed. The flame wrinkling depends on the turbulence intensity.
In non-premixed combustion, the flame propagation is mainly influenced by mixing. Models for non-premixed combustion usually account for the presence of fuel, air and burnt gases in each computational cell.
I can send you the Chomiak and Karlsson paper. However, you should have a look to the following books:
Theoretical and Numerical Combustion by Poinsot and Veynante
and to
Turbulent Combustion by N. Peters
They should be very helpful to understand which model is more suitable for your case.
Regards
Tommaso
Old   September 18, 2008, 05:02
Default Dear Tommaso I am working o
Ahking Chou
ahking520 is on a distinguished road
Dear Tommaso
I am working on composite propellant combustion, would you please offer me some references about
PaSR model.
ahking520@gmail.com
thank you in advance!
ahking520 is offline   Reply With Quote
Old   March 2, 2009, 14:17
Default Tommaso, Hi. I was wondering
  #11
John Paul Handrigan
jphandrigan is on a distinguished road
Tommaso,
Hi. I was wondering if you could send me some additional information regarding the PaSR model.
jhand085@uottawa.ca
Thank you in advance!
John Paul Handrigan
jphandrigan is offline   Reply With Quote
Old   March 3, 2009, 19:14
Default Hi Tommaso Can reactingFoam
  #12
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Tommaso
Can reactingFoam solve for a deflagration to detonation transition ? ( characterize a standing detonation wave in a reacting flow ) or no ?
Maybe Xoodles can do this...? The idea is that the increase in pressure caused by the DW causes the non reacted premix to ignite, if the non reacted flow flows with a supersonic speed, since the Detonation wave travels at most at the sound speed of the detonation products, i guess that either reactingFoam or Xoodles could allow me to simulate this...
Am I right here...?
Thanks for your help
Best regards
Alex
alexandrepereira is offline   Reply With Quote
Old   March 3, 2009, 19:28
  #13
Alexandre Pereira
Hi Tommaso
Am I right here...?
Best regards
Alex
Old   April 15, 2009, 21:32
Smile
  #14
Xu Bo
Acebobo is on a distinguished road
Deer Tommaso,
Hi. I was wondering the PaSR model in OpenFoam. Is it same as Fluent PDF method? Can u give me some hint?
bobo1314@126.com
Xu Bo
Acebobo is offline   Reply With Quote
Old   April 16, 2009, 03:28
Markus Rehm
markusrehm is on a distinguished road
Hi Xu B,
no the Chalmers PaSR is entirely different from the PDF approach. It is rather related to EDC. For more information look at the thesis of Fabian Peng Karrholm here:
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/
or check the code in chemistry.H of the reactingFoam solver.
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   April 5, 2011, 17:10
Default Chomiak and Karlsson paper
  #16
Yashar Afarin
yashar.afarin is on a distinguished road
Send a message via Skype™ to yashar.afarin
Hi Markus,
I would really appreciate if you could send me the " Chomiak and Karlsson paper". my email is: yafarin@gmail.com
Best regards
yashar.afarin is offline   Reply With Quote
Old   May 22, 2011, 09:40
Yashar Afarin
Hi dear fomers
As you may know, reactingFoam suppose that the Lewis, prandtle number and schmidt number are equal one. so the each species transport equations are as shown in the Yeqn code.
Has anyone used "binary mass diffusion coefficient" in the Yeqn equation?
I would appreciate it if someone could help me to use reactingFoam with different diffusion coefficient.
Kind Regards,
Old   April 25, 2013, 06:57
Camille
camille131 is on a distinguished road
Hello Tommaso,
Thank you in advance,
camille@ccii.be
camille131 is offline   Reply With Quote
ReactingFoam solver muthukaalai OpenFOAM Running, Solving & CFD 1 June 16, 2008 14:36
ReactingFoam solver restart gcollecutt OpenFOAM Running, Solving & CFD 0 August 9, 2007 06:30
Looking for description of sonicTurbFoam tangd OpenFOAM 0 June 13, 2006 02:20
CFD description jordi Main CFD Forum 3 March 26, 2004 12:14
Brief description of CFD John FLUENT 4 December 3, 2002 00:43
