Wall Shear Stress (WSS) in a Straight Circular Pipe Using simpleFoam |
Yesterday, 03:18 |
Yoshiki
I am using OpenFOAM v2112 to calculate wall shear stress (WSS) in a straight circular pipe model and compare it with theoretical values. For the analysis, I am using the wallshearstress utility under postProcess. When I compare the computational WSS values with the theoretical ones, the computed value is approximately 0.3 Pa, which is about 50% lower than the theoretical value of approximately 0.6 Pa. I am struggling to resolve this issue. I have tried varying the mesh size (0.1 mm, 0.3 mm, 0.5 mm) and boundary layer settings, but the computational result remains around 0.3 Pa in all cases. Model specifications: Straight circular pipe: Diameter: 0.005 m Length: 0.05 m Mesh: Generated using cfMesh [cartesianMesh (hexahedral mesh)] Mesh size: 0.3 mm Boundary layer: 10 layers, each 0.01 mm thick Boundary conditions: Inlet: Average velocity of 0.21 m/s applied Outlet: patch (pressure condition) Walls: No-slip condition Other settings: Solver: simpleFoam (steady-state) Laminar flow Newtonian fluid with a kinematic viscosity of 𝜈=3.301×10−6m^2/s For post-processing, I used ParaView to calculate WSS by multiplying the output of the wallshearstress utility with the fluid density. I also tried running the same analysis with pisoFoam (unsteady simulation), but the WSS still remained around 0.3 Pa, which is lower than expected. If anyone could provide suggestions on how to accurately calculate WSS, I would greatly appreciate it. velocity.xlsx |
openfoam2112, wall shear stress |
[snappyHexMesh] How to draw a 3D-Drawing for Meshing | Kahnbein.Kai | OpenFOAM Meshing & Mesh Conversion | 4 | June 15, 2021 13:16 |
Ansys CFD-Post Application Error | rushiCFD | FLUENT | 0 | March 21, 2021 08:51 |
Calculating the Wall Shear Stress Gradient over surface | 123catty456 | Main CFD Forum | 1 | October 1, 2012 23:27 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
Flux depending on wall shear stress in Fluent 5.2 | Andreas Borg | FLUENT | 0 | June 7, 2000 07:27 |
