innerSqr() function in SSG model
Old   December 8, 2024, 18:23
Default innerSqr() function in SSG model
CPark
ckpark is on a distinguished road
Dear all,
While going through the transport equation of Reynolds stress tensor in SSG model of OpenFOAM foundation distribution, I came across a couple of differences compared to the definition in the original paper by Speziale in 1991.
The first difference is from the 4th term: b_{ik}b_{kj}-1/3b_{mn}b_{mn}\delta_{ij} is defined in the source code. Instead of a simple inner product of two tensor (e.g. A&B), it is in the code: dev(innerSqr(b)).
When I went to look up the definition of innerSqr(), it did not look anything like b_{ik}b_{kj}.
The second difference is from the 1st term: simply the \bar{S}_{ij} being defined as dev(S) instead of simply S.
Does anyone know where these differences arise from or why are they implemented as such?
Thank you!
ckpark
ckpark is offline   Reply With Quote
Old   December 9, 2024, 05:27
Tobermory will become famous soon enough
I am not sure which bit you are worried about ... b is a symmetric tensor
 inline Foam::SymmTensor<Cmpt>::SymmTensor
     const Cmpt txx, const Cmpt txy, const Cmpt txz,
                     const Cmpt tyy, const Cmpt tyz,
                                     const Cmpt tzz
     this->v_[XX] = txx; this->v_[XY] = txy; this->v_[XZ] = txz;
                         this->v_[YY] = tyy; this->v_[YZ] = tyz;
                                             this->v_[ZZ] = tzz;
so b_{ik}b_{kj} is correctly calculated by the innerSqr function:
 //- Inner-sqr of a symmetric tensor
 template<class Cmpt>
 inline SymmTensor<Cmpt>
 innerSqr(const SymmTensor<Cmpt>& st)
     return SymmTensor<Cmpt>
         st.xx()*st.xx() + st.xy()*st.xy() + st.xz()*st.xz(),
         st.xx()*st.xy() + st.xy()*st.yy() + st.xz()*st.yz(),
         st.xx()*st.xz() + st.xy()*st.yz() + st.xz()*st.zz(),
         st.xy()*st.xy() + st.yy()*st.yy() + st.yz()*st.yz(),
         st.xy()*st.xz() + st.yy()*st.yz() + st.yz()*st.zz(),
         st.xz()*st.xz() + st.yz()*st.yz() + st.zz()*st.zz()
(write out the terms if you want to check this, noting the storage convention for symmetric tensors in OF).
And then in OF, dev(F) returns F - 1/3 \delta_{ij} F_{ij}, which matches the expression you quoted b_{ik}b_{kj}-1/3b_{mn}b_{mn}\delta_{ij}.
Am I missing something? Perhaps I misunderstood your initial question?
Tobermory is offline   Reply With Quote
Old   December 9, 2024, 08:33
CPark
Thank you for your answer, Tobermory.
You're absolutely right, I mixed up the index notation. Is it then correct to say that innerSqr(b) represents b_{ik}b_{jk} while b&b represents b_{ik}b_{kj}?
Do you perhaps have an idea on the second question in my original post where \bar{S}_{ij} is computed as dev(S) instead of just S?
Old   December 10, 2024, 08:26
For a symmetric tensor, like b, b_{jk}=b_{kj}, and so innerSqr(b) represents both b_{ik}b_{jk} and b_{ik}b_{kj}. As does [LaTeX Error: Syntax error].
Why not just use &? I guess because innerSqr uses the symmetric tensor storage form, and is more compact? Dunno.
As for the second question, if the flow is incompressible (as was Speziale et al's assumption in their paper), then znabla \cdot U = 0 and S \equiv dev(S). Maybe OF made it deviatoric to force the term to have zero trace, i.e. to cater for non-incompressible flows or to improve convergence? Not sure.
innersqr, openfoam, rsm, ssg
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
