December 8, 2024, 12:31 |
Overset Mesh in IC engine?
Jigs
Rep Power: 9 |
Hello Everyone,
I am trying to simulate IC engine without combustion, I was thinking whether we could use overset mesh to simulate movement of valves and piston? I read somewhere that in overset mesh the walls cannot cross, so how should I model stem of valve here. Here is a look of the model I have prepared for simulation. Any thoughts/suggestions are most welcome. Last edited by jmex; December 9, 2024 at 07:05. Reason: removing image from thread, as it is in attachment |
December 9, 2024, 07:08 |
Jigs
Rep Power: 9 |
can someone suggest a way to perform such simulation (if not overset). And if so, just want to know if this is possible at all for the walls to intersect.
I need to know so that I can focus and work in that direction. Any suggestion are most welcome. |
engine, ic engine, overset mesh |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
Overset simulation fails when using 2 close together overset + background mesh | quarkz | OpenFOAM Running, Solving & CFD | 0 | January 7, 2021 03:36 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
