Periodic massFlowRate
Old   December 4, 2024, 01:06
Default Periodic massFlowRate
Zhicheng Kai
dandanTT is on a distinguished road
Hi Foamers,
How can I define a FlowRate boundary condition for a inlet that varies with time? For example, flowrate = sin(t). Thank you all for helping.
dandanTT is offline   Reply With Quote
Old   December 5, 2024, 06:03
Renato
RenMon is on a distinguished road
hello, I think you can try using the "flowRateInletVelocity" boundary condition and then specify "table" in the value section. Something like this:
inlet
type flowRateInletVelocity;
uniformValue table
(0 1)
(0.1 2)
(0.2 3)
(0.3 4)
in this way the flowrate will be linearly interpolated between the time values (0; 0.1; 0.2; 0.3). You just need to create a sine function and use it in the table section. I never tried this but it should work. Otherwise, you can use the boundary condition "uniformFixedValue". In this case, you should compute the velocity starting from your patch's area and flowrate and then use the same strategy with the table. For example, by assuming that your patch is a plane patch of normal (1 0 0):
inlet
type uniformFixedValue;
uniformValue table
(0 (1 0 0))
(0.1 (2 0 0))
(0.2 (3 0 0))
(0.3 (4 0 0))
RenMon is offline   Reply With Quote
Old   December 5, 2024, 17:58
Zhicheng Kai
Thank you for your kindly reply.
"uniformFixedValue" does not work in my case.
The "table" method might be working, but while looking, I realized other options like "sine" or "codedFunction1" from this page. However, I have no idea how to set it up.
boundary condition, function of time, openfoam, time-varying bc
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 16:36
Turbomachinery Mass imbalance sheaker CFX 12 September 5, 2019 09:09
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 18:00
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 09:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 18:46
