solids4Foam restarting issue
Old   November 27, 2024, 07:21
Default solids4Foam restarting issue
Renato
RenMon is on a distinguished road
Hi all, I am facing some problems in solids4Foam when I use the boundary condition "displacementOrTraction" and "fixedDisplacementZeroShear". In both cases, the simulation (solid only) starts without issues and gives the expected results. However, when I try to restart the case from a saved field, I get the following error:
--> FOAM FATAL IO ERROR: (openfoam-2012 patch=210618)
Expected keyword 'uniform' or 'nonuniform', found on line 622738: label 0
file: myCase/0.005/D.boundaryField.fixedDirZ at line 622735 to 624105
RenMon is offline   Reply With Quote
restart, solidmechanics, solids4foam
[solids4Foam] Missing interpolate(sigma0) in fvSchemes in some tutorials Krapf OpenFOAM CC Toolkits for Fluid-Structure Interaction 8 June 23, 2024 08:59
Issue with MULES alpha GardenLake OpenFOAM Running, Solving & CFD 7 March 25, 2024 12:35
solids4Foam & FOAM-FSI farah.elias OpenFOAM 21 August 28, 2023 16:57
solids4Foam thermoelasticity hotCylinder tutorial with non-linear material cedwilli OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 May 19, 2023 15:54
CAMWA special issue on open-source numerical solver feixu2019 SU2 News & Announcements 0 October 1, 2018 12:19
