Error while using functions in OF 8
Old   November 11, 2024, 11:09
Exclamation Error while using functions in OF 8
Hamed Hoorijani
Hamedhoorijani is on a distinguished road
Hi everyone,
I'm facing an error while running simulations that include a function, whether it's used in controlDict or as an fvOptions. I have compiled OpenFOAM 8 using the source code, and everything else is working perfectly. However, I am facing this issue specifically when trying to utilize a function, which results in the following error:
--> FOAM FATAL IO ERROR:
error in IOstream "OSHA1stream.sinkFile_" for operation Ostream& operator<<(Ostream&, const word&)
file: OSHA1stream.sinkFile_ at line 0.
    From function virtual bool Foam::IOstream::check(const char*) const
    in file db/IOstreams/IOstreams/IOstream.C at line 96.
FOAM exiting
OF compiles without errors, and removing the functions simulates the same case without issues. I would appreciate your help with this.
Thank you in advance.
Hamed
Hamedhoorijani is offline   Reply With Quote
function objects, openfoam, openfoam8, simulationsetup
CHT turbulence model wall functions julieng OpenFOAM Running, Solving & CFD 5 January 31, 2023 18:37
UDF to disable wall functions Abhinand Fluent UDF and Scheme Programming 3 June 15, 2020 17:05
How to solve the boundary layer without wall functions? WhiteW OpenFOAM Running, Solving & CFD 4 January 20, 2020 05:55
[Commercial meshers] CCM+ Mesh Conversion Ingenieur OpenFOAM Meshing & Mesh Conversion 17 February 2, 2014 10:34
User-Defined Functions Boisson FLUENT 2 January 18, 2002 23:09
