Precusor Simulation Using Cyclic BC
Old   November 10, 2024, 19:30
Default Precusor Simulation Using Cyclic BC
Kevin Flora
kflora is on a distinguished road
Hello FOAMERs,
I am trying to setup a simple precursor simulation using OpenFOAM 5.0 (I know this is quite old, but I need to use it for other reasons) a rigid lid for a simulation of flow in a flume so that I can develop the flow for inflow characteristics of future simulations. I am using RAS with k-omegaSST with pisoFoam.
I setup the boundaries in my blockMeshDict as:
boundary
inlet
type cyclic;
neighbourPatch outlet;
faces
(0 4 7 3)
outlet
type cyclic;
neighbourPatch inlet;
faces
(1 2 6 5)
top
type wall;
faces
(4 5 6 7)
bottom
type wall;
faces
(0 3 2 1)
frontAndBack
type wall;
faces
(0 1 5 4)
(3 7 6 2)
and my 0/U as:
internalField uniform (1 0 0);
boundaryField
inlet
type cyclic;
value uniform (1 0 0);
outlet
type cyclic;
top
type slip;
value uniform (0 0 0);
bottom
type fixedValue;
frontAndBack
type slip;
and 0/p as:
internalField uniform 0;
boundaryField
top
type zeroGradient;
bottom
type zeroGradient;
inlet
type cyclic;
neighborPatch outlet;
outlet
type cyclic;
neighborPatch inlet;
frontAndBack
type zeroGradient;
turbine
type zeroGradient;
The case does run cyclically;however, while the flow develops a vertical profile, it loses velocity (and mass) as the flow develops. As shown in the attached 2 files showing a Slice in the spanwise direction of the velocity, the flow at 10 seconds is 1 throughout most of the flow (except at the bottom with has a fixed condition), but by 100 seconds, as the flow develops, the velocity magnitude throughout most of the flow is less than 0.5.
My goal is to have an average velocity throughout the flow of 1 and so I would expect velocities to redistribute with velocity magnitudes near the surface to exceed 1.
Clearly, something is still wrong. Any suggestions are greatly appreciated.
kflora is offline   Reply With Quote
Old   November 11, 2024, 07:59
Shravan
Severus is on a distinguished road
From what I see, this reason could be due to not applying a source term that will drive the flow.
Check out my answer here: 3D channel flow cyclic BC's pisoFOAM
Thanks
Severus is offline   Reply With Quote
Old   November 14, 2024, 11:50
Kevin Flora
Severus,
Thank you for you advice. This took care of my problem nicely and now have the correct velocity profile.
cyclic, openfoam, precusor
High time step continuity errors when activating RAS model smhk OpenFOAM Running, Solving & CFD 0 August 24, 2024 19:06
cyclic patch error cesarjets OpenFOAM Pre-Processing 0 July 25, 2023 21:14
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
time step continuity error increases with time_SRFSimplefoam mostafa kamal OpenFOAM Running, Solving & CFD 7 October 2, 2019 03:00
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 08:07
