November 2, 2024, 10:30 |
Change a name in cellzones
Pierre Lecanu
Rep Power: 2 |
In my “cellZones” file in the “constant/polyMesh” directory, the name is defined as “movingZone0”.
I would like to change the name movingZone0 to movingZone1. I think I need to create a file topoSetDict Can you help me create this file? Thanks /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2406 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class regIOobject; location "constant/polyMesh"; object cellZones; meta { names 1 ( movingZone0 ); } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 1 (movingZone0 { type cellZone; cellLabels List<label> 1682 ( 0 1 |
November 7, 2024, 04:17 |
Jan
Rep Power: 20 |
you can change the entry directly in the file, just rename with a text editor
November 7, 2024, 05:02 |
Pierre Lecanu
Rep Power: 2 |
Thank you
Of course, it's possible to make the changes with a text editor. But you'll have to do it every time. In the Allrun.pre file, I've inserted cd constant/polyMesh sed -i “y/movingZone0/movingZone1/” cellZones cd .. && cd .. |
cellzones, cellzoneset |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 03:03 |
change the under-relaxation factors | hotboy | FLUENT | 4 | May 28, 2015 23:25 |
No density change - rhoSimplecFoam | krapic | OpenFOAM | 1 | November 29, 2014 19:39 |
DecomposePar and CellZones | Anne Lincke | OpenFOAM | 4 | October 13, 2010 10:18 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
