buoyantPimpleFoam: natural convection with free openings setup
Old   October 30, 2024, 09:38
Default buoyantPimpleFoam: natural convection with free openings setup
SadBoySquad is on a distinguished road
Greetings to all FOAM'ers here!
I am still trying to find a proper setup for a natural convection + buoyancy case with multiple free openings that the flow can enter and exit based on buoyancy-induced currents inside the domain.
I think I've read each and every one of the relevant threads I found here regarding these types of cases, the most relevant being:
(I seem to remember a couple more threads that had relevant info and that I may have gathered some additional tips, although I cannot seem to find them right now)
In the following link you can get my full setup directory for a simple buoyant box:
  • a low opening on the left and a high opening on the right
  • bottom wall takes a fixed temperature or a heat flux
  • flow should enter from the left opening (low) and exit through the right opening (high)
https://www.dropbox.com/scl/fi/e9x1y...prw7k6vmo&dl=0
Short BC info:
U:
  • walls noSlip
  • openings pressureInletOutletVelocity
p_rgh:
  • walls fixedFluxPressure
  • openings prghTotalHydrostaticPressure
ph_rgh:
  • fixedFluxPressure everywhere
  • function that initializes ph_rgh in controlDict
epsilon|omega|k:
  • wall functions on walls
  • inletOutlet on openings
T:
  • same as above, with only the bottom wall having a fixedValue or an externalWallHeatFluxTemperature BC
Overall things that I've learned trying to run this case:
  • You have to initialize ph_rgh accordingly, because otherwise the fluid will produce flow due its own gravity force
  • Even with 0 temperature difference (which should be a domain with 0 velocity), the solver produces some definitely non-zero velocities (they are in the order of magnitude 1e-02)
  • The case needs to be run with buoyantPimpleFoam because buoyantSimpleFoam produces high artificial velocities (even without temperature differences)
The thing that bugs me is that the flow takes literally forever to converge into a steadyState-like state. Moreover, I am not quite sure that my setup is correct and I cannot move to more complex cases (which is my final goal).
Is this BC setup the best thing we can do in openFOAM? Should I try something different?
SadBoySquad is offline   Reply With Quote
buoyancy, natural convection, openfoam, p_rgh
Heat transfer between two closed cavities with natural convection Czarulla FLUENT 2 August 5, 2020 13:36
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Natural Convection around two spheres in a box - chtMultiRegioSimpleFoam salvo-K61IC OpenFOAM 4 January 16, 2015 14:27
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 20:43
Mixing By Natural Convection Processes Greg Perkins FLUENT 0 February 12, 2003 19:40
